Computers & Internet Logo
Question about Acer Computers & Internet
How can I remove the base & stand of my Acer S240HL monitor?
I have removed the base and am left with the stand. Can't seem to find the proper release and I don't want to force it out as I may want to use it again in the future.
  • The Spaminator
    The Spaminator Jul 29, 2021
    Hi Anonymous, does it have a plastic lever locking base into monitor ?
    in the back of the monitor
    may need to release via the hole pressing in with a screw driver while gently pulling base out
    Can you please add details in the comment box?
How to remove the stand of ACER LCD monitor H163HQ?
You should see a ***** located on the round base,just remove that with Philips(star) ***** driver and that`s it :)
1helpful
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
How to remove the base
I have an AL2223W. It has 4 screws on the back that allows the stand to be removed. See if yours has that.
1helpful
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
2answers
Acer p221w monitor removing base
Since you have surely looked, it isn't held on with exposed screws.
Check to make sure that the rounded area that allows tilting is not part of the case but appears to be separable.
Most that are removable are held by a tongue and a fairly obvious release tab.
if you can't remove the base, just place the monitor in the carton on good padding and upside down.
Fill and cushion the sides well, mark the carton with 'This side up' and an arrow and hope there are no malicious handlers on the trip.
I've shipped numerous monitors of different sizes and types and have lost none of them to shipping damage.
3answers
Acer AL1917W goes black
Are you sure that the monitor is the problem?
Did you check the video card?
Did you check your monitor in another computer?
Hoe do I remove teh attached stand on an ACER AL 1913?
Where the footpiece joins up with the screen, you'll find a round cover from left to right which just clips in. carefully squeeze the ends and pull away untill released. under the cover you'll find four screws that holds the footpiece and screen together. Good Luck, jus004
2helpful
5answers
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Steve Sweetleaf
Steve Sweetleaf
shadow
