A second long flashing sound but no picture on a 60pv250 LG tv
When I turn tv on with a remote TV have a clicking sound but no picture. If I have it on TV I hear a noise sound and if it on bluray I can only hear the movie but no picture ...HELP PLSE
Posted by Santuario on
    Top Expert:
  • Televison & ... Master
  • 76,763 Answers
If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault . Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Posted on Jul 31, 2021
I have a LG 60PV250, when I turn my TV on I have sound, however a quick light flashes on the screen (not the entire screen just bits as if it's a scattered broken up picture) for a second and then screen...
Well.hello friendly customer do you know that that's a plasma TV that TV is dangerous and that TV is not easy to fix most anybody on here can I help you but I can tell you this much if you still have sound but you don't have picture in the back of the TV there are three boards on the left side two are buffers what is called the sustain board 1 or all of those boards are bad now look take this TV to a shop because if you're not experienced and you try to work on it you will ruin the rest of the boards in the back of that TV that I can guarantee
My TV doesn't have picture its fuzzy in different areas not the whole screen and makes with clicking noise when its turning on.
Invariably the HDMI cable that you are using to connect the signal is bent and pressing hard against the wall. Can you verify with other ports and other sources.
How to repair a tv LG plasma 60pv250
Sounds like your Power supply is still good. but maybe the board for the video is bad.. (maybe the main board other than power supply. If you do a search on the internet for "60pv250" and "board". you can find replacement parts. If you are capable or know someone with some electronics skills you should be able to see if any parts on the existing boards are popped (sounds like a capacitor went) and then buy the right board
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Plasma model 60pv250. Have sound, but why no picture?
Quite possible, plasma are notorious about power they over heat tremendously, So quite possible is the power board, its really hard to pin down in a plasma, you are stuck in buying extra parts just to see if it works. i had 2 and the power supply didnt help, but good luck in your adventure it is a learning experience
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
I HAVE A LG 60PV250-UB IT HAS SOUND BUT NO PICTURE. HOW CAN I FIX THE PROBLEM?
replace the power board with the exact same part number on the board it self.
On/off problems with my LG 37LC7D TV. It is hooked up to Direct TV
You need to contact a local TV repair service, UNLESS you have the tools and the repair manual to repair it yourself, it will take diagnostic work to determine what is the cause, one thing is for sure you have a defective circuit board.
Turn the TV on, clicks back off - no sound, no picture
hello, your power supply has to be repaired and you are looking at $275.00 for this job
good luck
Televison & Video Logo
Top Televison & Video Experts
Ekse
