T-con board replacement ?
Hello, I have a Samsung tv and it had a black screen with just sound. Just replaced a T-con board and I powered it up. The display showed "Smart Tv" on the screen for a few seconds and then everything went blank like before. I tried removing the power and powering it up again but display does not show "smart TVs" like before. Could this be a bad display or fault T-con board.
Larry
  • Televison & ... Master
  • 3,158 Answers
The model would have helped but it sounds like you have bad LED back lights, generally a bad timing board will give a scrambled picture or a blue screen if defective. The lamps are drawing to much current and the safety circuitry in the power supply is shutting off the supplies to the backlights
Posted on Jul 28, 2021
Testimonial: "It is UN65JU670DF. Does that mean the LED burned the new T-Con I just replaced. Any suggestions how to check the LEDs."
  • Larry Jul 31, 2021
    Your T-con board is not defective, a bad tcon board will give a distorted picture or in some cases a blue screen. The LED backlights are strips of button lamps that light up the panel so you can see the picture, you have some shorted buttons on the strips so all the strips need to be replaced. On a set of that size it's not going to be a fun job to do, if you decide to replace them watch lots of youtube vids and be VERY careful with the panel, the panel will have boards connected to the bottom, be really careful with those as the connecting strips can be damaged then the set is junk ( I tape them to the panel when I remove it) nothing worse than spending money on new strips, get them in and everything back together and find the panel has been damaged and the set is no good. You can find the strips on shopjimmy.com, they will run around $90 with shipping and sales tax...Good luck!
    Top Expert:
  • 76,758 Answers
If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault . Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box.
Posted on Jul 27, 2021
I have a Samsung UN55J620DAFXZA 55" LED TV with black screen (no picture) & no sound.
1. Disconnect the cable between the main power supply & main board, supply AC to the TV, if the LED strips are OK, it should light UP, if not replaced all of the LED strips.
2. If the back lights light up, but no display or sound, replaced the main board.(after you re-connect cable).
Samsung led tv gets power but see no picture. sometimes have heard sound when toggling through inputs. I replaced the T-con Board and the TV worked fine for a while. Now I'm not sure what to do.
LG LED TV has no picture (black screen) but still has sound - can ...
www.tomsguide.com/answers/id-2660992/led-picture-black-screen-sound-fixed.html
Feb 9, 2017 - My 32' LG LED TV has suddenly lost picture! The sound is alright but the screen is pitch black. ... Then completely black but with audio. ... I'm really hoping if I do the right research Ican fix this tv for my husband. .... Take the screen off hit power and watch LEDs if any don't flash its LEDs if they all flash its ..
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
No picture only sound on samsung tv
Test it this way. With the TV on and receiving a program, shine a flashlight on the screen If you can observe a faint picture then the T-Con board is working correctly but the back light ballast is not. Some models incorporate the ballasts on the power supply board. Others are on a separate board. Go here to get the correct parts to fix your TV TV Parts Universal TV Stands DLP Chips ShopJimmy
What board do I need to repair Samsung tv
Hi!,
I would replace the main board but check the power board before to see if it is ok. Good luck,
Serge.
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
1helpful
3answers
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
Hello! I have a samsung un32c6500 LED tv with a
Do you have sound? If you have sound and if the TV is responding to commands then I would say the main is fine. However if you don't have sound or video I would start with the power supply voltages. If you have sound and no video, I would suspect t-con but be advised, some manufacturers are building the t-cons into the panels !!!
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Ekse
