My blackpoint tv does not display anything when turned on it has a black screen
I can hear the sounds of the tv show when turned on but there is no image. how do I go about fixing this manually?
    Top Expert:
  • Televison & ... Master
  • 76,758 Answers
You can hear the sound of the show, means the TV's main board have no problem. The problem should be with its backlight inverter board. Just check it. Take a torch light, and light it on the screen, and see whether there is any picture on the background. You will see that, if the main board is OK. If so, concentrate on the backlight inverter board. It is common fault with most of the LCD TVs, irrespective of its brand. OK?
If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault . Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box.
Posted on Jul 27, 2021
2helpful
Lightening strike.....then 50" Insignia TV screen went black but you can hear it. Nothing will show on TV screen, not menu or anything!!! Help
If you can hear sound but no picture that means the Data Display Channel card is good and that there is hope to bringing it back to life.
Now LCDS use ccfl (cold cathode fluorescent) as the back light that means they are not lighting up; for some reason mostly the invert-er that steps up 12vdc or 24vdc to light the ccfl. Check if the invert er is receiving voltage if it is receiving but not stepping it up then the invert er must be changed. If there is light ,sound but no picture then replace the T-CON BOARD
Why does my blackpoint tv show my cameras in black and white
you cant plug it into the component plugs as you see it is b&W...you need to plug it into the AVI input which may be on the side of your TV or even the front depending on the model
JA
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
2answers
Watching TV and it suddenly turns off just like if you had the remote and shut off the TV. We set in amazement for a few seconds and then we turned the TV back on. We had sound but no picture. It was a...
Tv turn on now,does it have a flashes of picture only a few second than dies and than have only sound left?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards are one to the left one to the right both must be replace.The 2 long LCD inverter boards job are to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 LCD inverter boards for the replacement.
Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
2answers
Turns on but will not display anything on tv no background or anything power went off yesterday but is on serge protector same as tv
Try a video reset:
While the PS3 is off (solid red led) hold down the power button until you hear the SECOND beep, quickly release.
Let me know if that solved your problem.
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
2answers
Red light stays on
First before a reset the set must turn on, if the set just sits there with the red LED on you have further problems, so does the set display anything?
2helpful
3answers
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Televison & Video Logo
Top Televison & Video Experts
Ekse
