Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Hello - Error code CE typically indicates a communication issue between the user interface and main control board. Try resetting the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and restart unit. If the error code does not clean, contact a professional to move forward accurately for a proper diagnoses.
Hello Said Raji - Are you certain the error code is C8? Could it possibly be CE? If so, it typically indicates that the dishwasher has detected a configuration error. A professional will need to check the wiring connections between keypad and main control board.
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
