Question about Miscellaneous
CMOS battery for Inspiron 15 5100
What does it look like?
Posted by tom meadows on
ADMIN Canada
    Top Expert:
  • Miscellaneous Master
  • 40,361 Answers
How do you get to the cmos battery on a dell inspiron 1545 laptop
It's located just below the RAM modules on the bottom side of the motherboard.
Battery cmos location
Which model dell inspiron there are many ?????????
http://www.youtube.com/watch?v=iCTMOTlYikg&feature=player_detailpage
How to change the CMOS Battery Cell in your Dell Desktop Tower
How to change the CMOS battery in your Dell Desktop Computer
http://www.youtube.com/watch?v=ao866I9XpTo
dell dimension E510 possible Fix
http://www.youtube.com/watch?v=wHUvDhhbyv4
What type CMOS battery will fit a 1W766 motherboard
Hello here is the homepage:
http://www.dell.com/support/troubleshooting/us/en/ussoho1/Product/inspiron-8600
You have to order the battery from a dell service center.
It look like this:
But here could be a difference depeding how old the laptop is.
Here is the other type:
The dell dealer should know what right in your case.
Hope this will help you
Reset cmos password for DELL inspiron 1545
Remove the CMOS battery (CR2032 button battery) and reset the shorting plug to reset pin position.
Wheres the cmos jumper in dell inspiron e1405?
All you need to do is remove the cmos battery and main battery, short across the positive and negitive terminals where the cmos battery was, that will reset to factory default, however if you are hoping to remove a bios password this will not work no matter how long it is without power. The information is stored on a epprom chip.
Dell inspiron 530 cmos checksum
This error usually occurs when the CMOS/BIOS battery is flat.
Replace the BIOS battery and then boot up and go into the BIOS setting to setup the Date & Time etc.
1helpful
Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
3helpful
2answers
How to remove a cmos battery is a dell inspiron
The CMOS battery is located underneath the keyboard of your Dell i5100.
If you're up to it, then try these simple steps:
- Open the lid to a 180 degree angle and using a very small Flat Screwdriver, pry the hinge cover on the right side. There's a small notch where you can pry it out.
- Check if the keyboard is being held by 2 screws. To loosen them, remove the battery and unscrew them from inside the battery bay.
- Carefully lift the keyboard in an angled position and check the ribbon or contact tape that connects the keyboard to the motherboard. Flip the keyboard towards you and see if you can reach the CMOS battery (usually covered by a blue plastic shield or protective cover. There's a pair of wire coming from it and the end is a small connector. You may remove the connector attached to the motherboard carefully to get the CMOS battery.
Miscellaneous Logo
Top Miscellaneous Experts
Steven Wander
Steven Wander
Mohamed Alazhary
Mohamed Alazhary
Are you a Miscellaneous Expert? Answer questions, earn points and help others
