Question about Grilling
I have a oneida thermometer and my probe is not working can I buy a replacement?
Posted by timothy springs on
ray gallant
    Top Expert:
  • Grilling Master
  • 73,385 Answers
FIXYA IS NOT A RETIL OUTLET NOR DO WE KNOW WHO SELLS THEM
Posted on Jul 16, 2021
1helpful
Highest temperature for Oneida 31161 digital thermometer
The best information I could find was that the absolute maximum is 392 F (200 C). Exceeding this temperature will likely ruin the temperature probe.
I lost the instruction manual to our Oneida digital meat thermometer
The buttons should tell you what to do, they are all made be same people just take a few minutes to play with it. Normally set temp you want, or set time you want, pretty easy
Mar 23, 2014 • Cameras
No current temp
Inside the battery case is a "reset" hole. Use a paper clip and push it in while the temperature probe is on. The screen will flash and the unit will synchronize once again with the probe.
Oneida thermometer manual
The thermo temp says low but everything else is fine. I changed the batteries 3x. What should I do?
I have a used Tappan gas range with 4 burners and a griddle in between the burners. everything works, but the oven temp varies about 40 degrees above and below the setpoint. it never seems to level out...
not normal
problem thermostat not lighting the gas or turning the gas off to maintain an even temp
temp variation should be around a 10 degree range
call a gas fitter to check out the oven controls , thermostat or thermocouple
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
I have the same problem. The problem is the probe went bad. I had a friend with another sumbeam digital probe (the mavrick) put that probe into mine and the temperature reading was working properly. So, now I am looking for a replacement probe. but looks like I will have to just buy another digital meat probe.
Grilling Logo
Top Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Tom Chichester
Are you a Grilling Expert? Answer questions, earn points and help others
