well this might be a small shortcomming of this model but as silly as it sounds even if you use a external hose to drain water from unit the float inside bucket still is active in unit so i bet if you look carefully the little float in corner of bucket is Just " not quite right" a little adjustment of this and im sure you can get it running again
If the hose is connected to the tap on the drain pan/bucket, did you knock out the center of the hose connection on the bucket? If you didn't that's the problem. If that's not where your hose connection is located, do not put the bucket back in. It triggers the unit to fill the bucket and not use the hose drain. Keep in mind the hose must remain lower than the connection on the dehumidifier to drain properly.
This may not help because I'm not sure of what you have, but most dehumids when using a hose hook to a fitting on the tank. If that's what you have, before you hook the hose you have to either punch a knockout in the center of the hookup on the tank or cut it out. Hope this helps.
With most portable dehumidifiers use a bucket to catch the condensate. Then the bucket is full the dehumidifier stops, then you need to empty it and replace the bucket to get the dehumidifier to start working again.
To make this unit run continually, the bucket can be modified so a garden hose can be attached and the hose can be feed into a floor drain. To do this look at the bottom of the bucket, there should be a hose connector where you can attach a standard garden hose. You will need to drill out the center of the hose connector with a 1/4" drill bit. Then you can attach the hose to the bucket and the other end into the floor drain.
remove the hose and insert the water bucket and it will automatically switch over and when bucket is full it will shut off till the bucket is emptied again,please rate this on fixya,thank you
You should be able to connect the unit to a drain hose - then you won't have to empty the bucket. Have you tried that?
Otherwise, you only have 2 options I can think of:
1) empty the bucket frequently (before it fills up) or
2) siphon off a bit of the water before jarring the bucket
BTW, I eventually gave up on using dehumidifiers unless I was trying to dry out wet carpet. They are a hassel, and they are essentially A/C units that doesn't give you cool air.
Offhand, two possibilities: 1. erroneous sensor reading(s) causing system to respond likewise erroneously; and/or 2. firmware/software glitch.
Initially, I would suggest a full hard reset, that is unplug from the mains for an hour or so. This would normally revert the unit back to factory default (assuming no hardware problem). Additionally, you may want to check the sensor(s) like the a bucket full sensor often would be a float switch of some kind.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
That is what it is designed to do. Most dehumidifiers come with a hose connection on the bucket. To use this hose connection there is a knock-out inside the connection where the hose attaches that must be removed. The alternative is to empty the bucket when it gets full. Most Dehumidifiers are set up with a switch that will shut it down when the bucket gets near to full.
