Question about Samsung Televison & Video
Model UN60J620DAFXZA, Version EA03. Why doesn't it turn on?
TV stopped working wouldn't turn on. Relpaced the powerboard...screen and power button light flash...no picture...replaced motherboard...backlights flash but don't stay on. I don't know what else to do. Please help.
Posted by Mark Monaco on
Larry
  • Samsung Master
  • 3,206 Answers
You have bad LED backlights, it's a very common issue, it's unfortunate you spent money on boards that aren't bad, order new backlights here https://www.shopjimmy.com/bn96-29074a-bn96-29075a-led-backlight-strips-new-12/ It's about a 3 hr job to change them, take pictures as you take it apart, use extreme caution when handling the panel, it's very fragile, tape the panel board to the front of the panel when you remove it or it could get damaged, if your panel has side wheat chips don't set it on them or the panel may be damaged, watch several you tube vids...GOOD LUCK!
Posted on Jul 27, 2021
Samsung led 60 inch tv. issue
Count the blinks. It can indicate error codes. Then google for samsung tv error code.
Samsung LED 60' TV UN60J620DAFXZA not turning on? No red standby light? No backlights?
Did you try repairing the PS with a repair kit first then replace both the boards after that?
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Sharp LCD TV LC-37GP1U flashing green power light
Unplug the unit for 1 minute, replug and try again. If it doesn't work the power supply is faulted and it needs professional service.
6helpful
2answers
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Tv wont turn on
You can check the two board.
One is Power board another one is Y-main.
You can find right part with serial # & version #.
Samsung LN-S3251D
We have the same problem we have had ours for 2 months, went to turn it off the and the tv froze, could not turn it off or change channel. We had to turn it off at the power point, now it will not turn on at all. The red light flashes but no picture.
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
