Question about Measuring Tools & Sensors
I have a new XC0436 weather station that is showing time/date 12 hours behind. Tried everything possible but apart doing a manual setting the sync setting is wrong
It's a Digitech brand
Posted by Norman Biss on
Daniel
    Welcome Back:
    Visited the website for 2 consecutive days.
While trying to setup internet time syncing on my new XC0436 I found this question. The answer from Fred is a bit brief so I thought I should add some details. When the XC0436 is synced to an internet time source it gets the time in UTC. To convert this to local time it uses a manually entered offset. The user manual lists the following steps to adjust the offset:
1. press and hold CLOCK SET key for 2 seconds to enter time set mode
2. the first value displayed is the offset (it appears that only whole hours are possible)
3. press the up or down arrows on the back to adjust the offset (e.g. 08 for Hong Kong)
4. press and hold the CLOCK SET key to confirm and exit
Posted on Aug 30, 2021
Testimonial: "Thanks Daniel, it was so easy to follow & fixed the problem!"
Fred
    Top Expert:
  • 35,143 Answers
Select the correct country time zone.
Posted on Jul 14, 2021
Testimonial: "The weather station is synced to the wifi which has the correct time so it doesn't make sense."
  • Fred
    Fred Jul 15, 2021
    My computer is synchronised to the web but I can still select different time zones.
  • Norman Biss
    Norman Biss Jul 15, 2021
    My computer has correct time zone. Strange that apart from Chatham Island & South Australia all are hourly not half hourly which my weather station is showing
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
1helpful
CHANGE LOCATION ON MY 348NC weather station
Press and hold mode button till hour digits flash then press 12/24 or rcc buttons to change then press mode button but pay attention after time date is updated location will flash then you pick the city. Just don't go to fast or you will miss it! Hope this helps.
1helpful
Date shows AM, should be PM. How to change, nothing in manual ?
You mean time is only coming in AM. The clocks are usually 12-Hour display. So it should automatically turn to PM once you go past 12 hours. I am assuming you have the manual and you are correct it does not show separate setup for AM or PM. You simply keep increasing the hour until it passes 12:00 and it should go to 1pm. Similarly once you go past 00 hours (midnight) it will switch to AM.
Hope this helps.
Manual for reference (won't help you if you already have it)
http://www.acurite.com/media/manuals/02010_02014_02015-instructions.pdf
3helpful
Need a manual for model cs1203 craig weather station
To change the time, press the time button. When it goes to 2000, you will see the date flashing. Adjust using up and down buttons. Then press the time button again. You can then use the up and down buttons to adjust the time. Finally, to toggle between F and C, use the up button by itself. To adjust between 24 and 12 hour clocks, press the down button.
Incorrect Date
open shortcut on pc..it will show correct date, time, etc tho unit does not as it hasn't changed days..on the shortcut, click on Update settings then Send to receiver..then punch in button on back of Station..says "pc search"..transmitter on unit will start steady flashing..unit will go black..gradually everything comes back..don't touch until all back..everything will now match the stuff on the shortcut and the day and date will have changed to the correct one..I do this process every day.
Module 3070 - PAW1300 > AM / PM problem apparently. Everything works except day and date 12 hours behind. EX: In HNL (Honolulu) on Monday morning, September 6 watch gives correct time, but shows SUN...
Hi, Obviously you need to roll the time 12 hours ahead. If the watch doesn't receive the Atomic signal properly at first, go to page three of your manual, and try doing it manually following the detailed procedures there.
If you don't have the manual, get it here:
http://world.casio.com/wat/download/en/manual/
Take the four-digit (3070) module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
2answers
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
15helpful
Operating Instructions Model No BA218
Setting the time and calendar
1. Press the [TIME] button once to enter Time Mode. The display shows the current time with hour, minutes, and seconds digits.
2. Press and hold the [SET] button for more than one second. The "Hour" digits of the time will begin flashing.
3. While the "Hour" digits are flashing, press the [^] or [down] button to set the desired hour time. Note: Press the [^] or [down] button once to advance the setting forward or backward by one digit. Pressing the [^] or [down] for more than one second will accelerate the forward or backward setting at a higher rate.
4. When the desired hour time is reached, press the [SET] button again. The "Hour" setting will be confirmed and the "Minute" digits will begin flashing.
5. While the "Minute" digits are flashing, press the [^] or [down] button to set the desired minute time.
6. When the desired minute time is reached, press the [SET] button again. The "Minute" setting will be confirmed and the "Year" digits will begin flashing.
7. While the "Year" digits are flashing, press the [^] or [down] button to set the desired year.
8. When the desired year is reached, press the [SET] button again. The "Year" setting will be confirmed and the "Month" digits will begin flashing.
9. While the "Month" digits are flashing, press the [^] or [down] button to set the desired Month.
10. When the desired month is reached, press the [SET] button again. The "Month" setting will be confirmed and the "Date" digits will begin flashing.
11. While the "Date" digits are flashing, press the [^] or [down] button to set the desired Date.
12. When the desired date is reached, press the [SET] button again. The "Date" setting will be confirmed and the calendar setting is complete.
Setting watch date, day, etc.
yes. i do this problem
Jul 04, 2008 • Watches
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Tom Chichester
ray gallant
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
