Question about Garmin Forerunner 405 Fitness Watch/GPS Forerunner 405, Black
Screen stuck on battery life indicator
Screen stuck on "battery life 96%" and can't get time or menu
Posted by shelaghm on
Michael Chaffin
  • 183 Answers
My guess is the battery was just changed? This watch needs to be cleared when the battery is changed. I recommend seeing a watch maker/technician to have the circuit board AC'd.
Posted on Sep 20, 2009
What is the life expectancy of the expedition
then it no doubt has run out of life and needs replaced with a better one perhaps .
Jan 31, 2015 | Timex Watches
Stuck on the start system update screen
I'm also stuck on this screen and if I try to update it keeps on saying "Failed" and can not go back.
Jan 01, 2013 | Oregon Scientific Watches
For about a month, while the watch did keep time, the second hand only moved 4 seconds at a time. In other words, it would no move each second, just in 4 second intervals. Now it is not keeping time,...
Your watch is fitted with EOL (end of life). This does not mean end of watch life, but end of battery life. Replace battery and watch will work as it should. Rate me, please.
Feb 27, 2011 | Omega Seamaster 300M Mid-Sz 2551.80.00...
The movement on the second hand is jumping every 5 seconds instead of every second, however the time is still correct.
Many high end quartz watches have a feature called the EOL or end of life indicator. This causes the seconds hand to jump 2, 3 or 5 seconds depending on the make of watch when the battery life is low. The watch will continue to keep accurate time until the battery dies completely. So, when you see your seconds hand jumping multiple seconds it is time to get a battery.
Oct 13, 2010 | Omega Seamaster 2561.80 Wrist Watch
The second hand on my cartier santos is ticking only every 5 seconds
This will be what is called the end of life indicator.There will be 2 or so weeks of life left in the battery,it still keeps time but will soon stop.Use a quality watchmaker to change the battery and ask about its water seal.
www.rolexrepairs.co.uk can help if you need more help.
Regards
Aug 04, 2010 | Cartier Santos W20056D6 Wrist Watch
Stuck on 02.10 hrs
You have to change battery. 3 years was a quite long service time for one battery. After replacement your watch will work as brand new. Rate me, plz.
Feb 03, 2010 | Tissot T Touch Navigator 3000 T96.1.488.42...
Second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Mar 20, 2009 | Tag Heuer 2000 Classic WK1311 wristwatch
Garmin Forerunner 405 Fitness Watch/GPS Forerunner 405, Black Logo
374 people viewed this question
Top Garmin Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Garmin Watch Expert? Answer questions, earn points and help others
