Question about Linksys Computers & Internet
Linksys WRT54G2 V1 suddenly stopped working
I have a Linksys WRT54G2 V1 and was working just fine till it randomly just stopped. All port lights are on, internet light is on, power light is barely lit, and the wifi light is off. The light stay on even if I removed all the port and internet cables. I tried to power cycle and reset but no change. I change power source and power adapter but no improvement. My computer doesn't even detect the router's wifi or direct connection to communicate, cannot access the router interface. I wasn't updating the firmware, just using the router via port.
  • 1 more comment
  • Larry Ng
    Larry Ng Jul 13, 2021
    it ran for 13 years, kinda amazing no?
    I guess you did not test the Ethernet ports first? P>>>Ethernet cable.>>> WRT54
    do that test first or wifi, has no hope, (as we say first things first)
    if yes the router part and your modem is good and ISP has not shut you down., 1 test 3 answers, bam.
    amazing no?
    so the wifi WRT light is out, that means its DISABLEd. (or worse, networking is dead, see above test)
    the manual for the router is free to see and read 24/7
    the router is reset 3 ways,
    1: the button marked rest for 1 second push, this is soft reset,
    2: long reset 5Sec+, do not do the long reset or all configurations and the wifi credentials you set up day one 13 years ago (lol) are gone.....
    3: or just pull the powerpack to the router 54 and put it back 1min. later,
    to see why the LED is off you must find the routers IP address.
    the default address new was, 192.168.1.1 (unless changed by you, < this is the 54G web page setups
    UN: blank ( day 1 new user name "empty")
    PW: Admin.
    many routers like this are dead( WIFI DEAD) now, due to AGE FACTORS.
    page 14 (10 real) covers wifi setup. (use IE11 to do setups, as others can fail)
    https://www.manualslib.com/manual/254051...
    learn this, new PCs flat hate accessing any old router due to new rules on Certificates that did not exist 13 years ago.
    it can be very painful, lacking experience doing the setups.
    BROWSER PAINS and cures.
    I use IE11, and click ignore 3 times... pain 1.
    I use Firefox and fails, v84
    I use Firefox, v20 portable ( a relic that loves old routers)
    try Chrome. older the better
    EDGE has no chance.
    that is the pain of using old routers. now.
    Id up grade the router, sure would.
    i just ripped out my neighbors 54G, (it had problems , going to sleep random)AGE related.
    https://www.amazon.com/ASUS-Dual-Band-Su...
    or go to a REAL ACCESS POINT
    UniFi 6 Lite Access Point × 1 (I have one here) hard wired to my Ethernet router, 1 cable.
    fast WIFI like you've never seen before.
  • Anonymous Jul 13, 2021
    buy an Ethernet cable first and connect it up, learn to test thePC to router to ISP , for full usage first.
    This is called testing the Gateway to the www internet first.
    if that fails test the Modem (ISPs) next to PC using the same cable,. if this works and router does not the router is toasted. or the ISP needs to setup your router again ask them.
    if all that works , the wifi part of the router is now dead. from 13 years being on.
    here are the full steps, short.
    buy a real Ethernet cable go broke $15 @ 15feet? a buck a foot, 2 RJ45 conns on each end male.
    even sold at walmart, it;s just a tool, and if you called a service tech, you see him do this first or after power resets. ethnernet must work first.
    1; test PC using Ethernet to router, same. must work good. to the web.
    2: if fail that .move the cable from PC to modeml direct, it must work to the web.
    3: if not reset both modem and router using the pull both power packs and put them back. (AC power pulled)
    4: still fails and modem too, well that modem is there, as is your ISP WWW connections.
    5: call them say your modem fails. (it is their modem) (in my case it is mine but that is me, bad boy)
    6: once the modem works (thanks to ISP) help. connect the router, for sure power reset.
    7: if the router fails now, it is bad.
    8: if you are brave (I am) do the long reset on the router, 10 second push power is on.
    9: ;the router is back to factory settings and lots of things to setup like day one new.
    10: modem works and router works at the ethernet ports and only wifi fails, then do not do #8
    11: wifi only dead you need to see your wifi settings @ 192.168.1.1, (if not changed by you or others)
    if settings are good and wifi is dead, play the RIP song. retire it to the LEAD Pb ROHS recycle center.
    my posts assume you know your wifi credentials.
    SSID name
    WPA2
    pass phrase.
    but wifi LED is dead . I use cell phone to test my wifi too, and a laptop, never just one thing tired, or fail you will.
    what is only the LED was bad,,,, LOL
    call geek squad,
    or learn to do the tests.
    or upgrade time (for SURE)
Fred
    Top Expert:
  • Linksys Master
  • 35,017 Answers
Disconnect the power to it, wait 5 minutes and power back on.
Posted on Jul 13, 2021
8helpful
2answers
I need a driver for linksys wrt54gs2 v1 wireless router
Hi mariervin
linksys wrt54gs2 v1 wireless router drivers can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Download linksys driver WRT54G2 V1
What drivers do you want to download?
There are not drivers for Linksys router. It works on a software called as firmware?
How many wireless computers do you have?
What is the operating system on your laptop?
If your wireless network is secured then make sure that you have the correct network key.
See How to setup Linksys router
See how to connect to the wireless network
5helpful
I lost my start up **** for my linksys wrt54g2 v1 wireless router where can i go to download it ?
You can download it from here,
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2
Select XP, Vista Setup wizard download.
Don't forget to give me a good rating as well as your vote.
9helpful
3answers
Upgrade Linksys WRT54G2 firmware failed.
there are 3 variants of the WRT54G2 , v1, v3 and v5 ensure that you choose the right firmware for the variant(its on the bottom of the router)
Go to the US site as this has more uptodate versions of the firmware.
For example v1 in the UK is at 1.0.0.0 dated 2008
v1 from the US site is 1.0.0.4 dated 2009
1helpful
I can't configure my linksys wrt54g2 v1
open a browser. type in 192.168.1.1 user name should be admin p/w admin if not, there should be a small hole in case, called reset. press this in while plugged in for 10 sec. then start again. once you are in you will find all the options. you may wish to refer to their website first.
2helpful
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Lost my cd for cisco wireless g WRT54G2 V1
I think, you can get the installer in the linksys website.
L have lost internet connection with linksys wrt54g2 v1 router. l am getting error 323
Stop using the setup disk. It does not work. Connect to your router via a web browser to 192.168.1.1. Username blank, input your password and configure the router as normal.
Set up my linksys wrt52g2 v1
Go to this site and scroll down to the section "Configuring your Router to work with Port Triggering"
http://portforward.com/english/routers/port_triggering/Linksys/WRK54G/Warcraft_III.htm
The username & password for the router is by default admin/admin.
Hope this helps
Open Questions:
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
