Cooktops Logo
J
Judy Bergmann Posted on Jul 11, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The burner-on indicator light is flashing for the right front burner on my Jenn-Air 9530ADW electric cooktop and the burner won't come on.
ADMIN Eric
Level 3:
Top Expert:
  • Jenn-Air Master 39,350 Answers
  • Posted on Jul 11, 2021
ADMIN Eric
Jenn-Air Master
Level 3:
Top Expert:
Answers
39350
Questions
0
Helped
794542
Points
588052
The flashing pilot light probably means the element has failed and it is in need of a repair.
2helpful
I have obtained a replacement element Whirlpool AP5653770 for my Jenn-Air JEC8430ADS cooktop. I have lost the secmatic I made showing the colopr of wires going to each position on the element. I have a...
This is the correct way to wire the right front burner on Jenn-Air JEC8430ADS cooktop. Let's do the red wires first. The red wire that comes from #2 on the switch goes to the common connection for the element that should be labeled 2a. The other red wire goes to either of the "b", hot surface indicator switch contacts and the black to the other. Use 1b or 2b for these connections whichever reaches easiest. The yellow wire goes to the inside loop of the burner and the tan to the outside element.
1helpful
My right front burner has stopped working.
no solution - just wanted you to know that I have had this model since 2004 and had to replace this burner twice under warranty and twice after that. It broke again 2 years ago so I just cook without it now. Will be replacing the cooktop and am resolved not to buy Jenn-Air/Maytag/Whirlpool products again - convinced it is a element design problem.
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
1helpful
2answers
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
1helpful
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
My jenn-air JEC9530 is red light blinking.
you will need a new heating element in and if that dosent work you need a new one
On light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
Jenn-Air Electric cooktop
did you replace the limiter the long rod that goes across the element or just the element everything i can find says that's the culprit
Jenn air electric cooktop
first, disable power to cooktop. next, replace either the mangled burner or the entire unit (after initial inspection leads to a logical prognosis)...sorry.
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
