Question about The Audio Players & Recorders
How do I hook the speakers up - The Audio Players & Recorders
  • The Spaminator
    The Spaminator Jul 10, 2021
    Hi Anonymous, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    hook up speakers to what ?
    what is output impedance of mystery device ?
    what are the speakers impedance ?
Hooked the stereo up and got power to but no sound coming out speakers but i try home speaker it work so what did i do wrong ?
if im understanding correctly what you wrote. you hooked up the headunit to the car and no sound from speakers, then you hooked up a single house speaker up and that speaker works fine. the Ohms on the car speakers might be too high, but most likely sounds like the wires to the speakers are bad.
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
I don't know how to hook up the speakers
hooking up speakers is easy you if your terminals are red and black you just match them up black on speaker means hook to black on the receiver doing a wrong hookup can reverse the phase of the speaker cause a distortion and eventual damage to speaker and coil.if you are rtunning just a stereo that allows two speakers select speaker you want for left side and put that on left of the stereo and hook it up as left and same for the right and if you have a home theater you hook it all up the same but you hook up the center put it in center front of the room as far back to wall as you can but dnt cover it up it should be lower than the front left and right or the main left and right speakers.then if the5re is surround you put those like say you have a square room you put them in the corners on the back wall.if you have rear speakers you put them on the back wall.make sure all speakers excepty rthe center are level and equal distance apart
Im hooking up a pioner dc deck i have power but cant get any of the speakers working dose it have like a factoy amp or something that need to be hooked up to use the speakers?
the speakers have a neg/positive wire make sure you hooked them up right easiest thing to do is hook up the power and start with two speaker wires once you have sound coming from a speaker label them with masking tape .
1helpful
Hooking up interior speakers
Just hook the last two speakers to two other speakers, Positive to positive, negative to negative.
Speaker set up problem
They hook to the rear surround.
HOW DO I HOOK IT UP TO MY NEW RCA FLATSCREEN TV?
how do you hook up x-530 speakers to a samsung tv
1helpful
Mixer 1622fxuli
The two plugs are what is called Daisy chained this means they are both the same. This is so you can simply hook the speaker to the amp, then from the other plug hook another speaker, then from that speaker hook another speaker, ect...
5helpful
Power middle speaker
Yes, you must hook the center speaker to a tuner, or it will not work.
Open Questions:
Top The Audio Players & Recorders Experts
Paul Carew
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
