This happens when the machine knows that you are using counterfeit or refilled toner cartridges. Or your toner refiller gave you an empty one, or one with a teaspoon of toner powder in it.
you must use OEM toner if you use aftermarket toner that says for use in you will get this problem if you have been using aftermarket toner you will have to change developer or empty all toner from developer unit and start with OEM toner Kyocera stamps their logo into cartridge
NO do not mix different types to toner. Major mistake that will cause the developer to go bad and even can cause fuser problems. toners are not the same. The have different percentages of ingredients depending upon the melt point of the fuser and the image density of the device. Printer Repair Service in Miami and Fort Lauderdale FL
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.
You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.
This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.
A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
