Question about Cutter Tools
Roland GX24 DPICS MODE any ideas?
Won't start up anymore. was working fine yesterday. any ideas what DPICS MODE even means? Cant seem to find any info on google. after awhile the screen just lights up squares and can't read anything on the LCD screen... no help from Roland.
  • Larry Ng
    Larry Ng Jul 29, 2021
    missing IN THE TITLE VINYL CUTTING MACHINE ! nothing to do with music or computers.
    dead roland keyboard no, it is a Roland GX-24 Vinyl Cutter.
    and is not a computer at all
    and is $2000 new
    like any thing made electronic that runs on AC power
    try it in 1 more room, AC power can be dead on one jack easy. so try 2nd room
    some rooms, jacks are all on GFI 1 is deed or all are in one room or 1/2 are.
    so try another room or use a hair dryer in the offending wall jack to see if it is dead.
    no idea me, DPICs means (zero google hits and in your manual zero)
    this Gx24 uses a AC to DC power pack for sure.
    it can be dead.( replace it)
    it can be the wrong one, mixed up with zillion other power packs most folks have and if you do that
    you can blow up the Roland to H3LL. facts hard. , always mark the pack with a sticker "GX24"
    or bad will happen i promise.
    his a
    , Roland CAMM-1 GX-24 24" Vinyl Cutter,
    the CAMM-1 uses 24vdc powerpack 2.8amps. (spec)
    using PC power pack 5vdc will never work (DEAD Machine, no harm)
    using power pack 48vdc will blow up the ROLAND.
    seen here
    https://www.manualslib.com/manual/604510...
    page 24
    read it.
What is wrong with my roland gx24 vinayl signlab 7.1
to get an answer to that question you will have to first comment on what it is doing that makes you think something is wrong
Windows won't start with safe mode
Download a new safemode for dell. my safemode wouldn't work too.
I tried to start my car this morning. There was no electricity at all and i mean at all, The power locks won't even work nothing. The car won't start, it's perfectly silent when you turn
You would need to use a meter or test light to find out what exactly is dead. It could be a short in the fuse box, or a bad connection in the harness, or at the battery or starter.
You may need a repair book or shop manual to get the wiring diagrams.
If nothing on the truck works, you would start at the battery cables and work back to the key switch.
1helpful
How to get out of dpics mode on a roland camm-1 pro gx400
Please help us the error code comes "dpics mode" in roland gx-500
Gas golf cart won't start
try a jump start off of a similar battery with the same voltage. If that does not work, there is a chance your ignition wire is not wired into the throttle anymore. try reconnecting it.
Bulldog deluxe 500.....can't get into programming mode.
I have been having the same problem. I was searching for the solution and found your question. Yesterday I tried the last thing I could think of and it worked. I unplugged everything from the black module. I left it over night I was coming home from work and wouldn't be going out to my car anymore but 15-30 minutes should be fine. Once I plugged everything back in, I was able to get into a programming mode. I was trying to change the start time. Hope this helps!
1helpful
Yesterday morning, I started my '01 4wd 6 cyl 2 door Blazer to warm up before work. It's below zero outside. It seems to start fine. I start driving, no more than a minute down the road it dies. I get a...
Hey rachelc516 it sounds like you going to need an alternator the reason i say that is the battery starts your car the alternator keeps your car running.
Computer screen freezes
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Jeep won start
check main fuse
year and kind of jeep ?
good luck
Cutter Tools Logo
Top Cutter Tools Experts
Tom Chichester
Wiscon Envirotech...
Level 1 Expert
Are you a Cutter Tool Expert? Answer questions, earn points and help others
