Washing Machines Logo
Question about Whirlpool duet Washing Machines
Where is the Filter on Whirlpool Duet Front Load ?
The model# is WFW9550WL00
Posted by Audrey Mc Clenan on
  • 3 more comments
  • Anonymous Jul 29, 2021
    A CLOTHES WASHING MACHINE IS NOT A COMPUTER. EVER
    SO POST TO WASHING MACHINES
    THE IS NO WHIRLPOOL Pc.
    JUIST 2 CLICK BROWSE +WASH, +
    https://www.fixya.com/troubleshoot/whirl...
    LEARN TO POST IN THE CORRECT FORM , AVOIDING , WRONG ANSWERS MAX HERE;.
    WHY NOT RTM , READ THE MANUAL
    GOOGLE MACHINE MODEL + THE WORD MANUAl.
    AMAZING YOU FOUND IT IN 1 SECOND FLAT.
    OR IS Having geeks read it to you wise or good.? no.
    I read the manual and is only a washer , no dryer, so there is no dryer lint filters here.
    only optional water filters or as the manual states, IRON filter. page 23
    WFW9550WL00https://www.searspartsdirect.com/manual/...
    my guess, is you have a dryer but never told make or model of that dryer.
    no problem stated or what filter means.
    here is the noise filter
    https://www.appliancepartspros.com/whirl...
    there are 3 types of tech filters.
    electronic, AC or DC noise filters
    air (lint filters)
    and water filters.
ADMIN Andrew
    Top Expert:
  • Whirlpool Master
  • 57,110 Answers
Moved to Whirlpool Washing Machines Category. I see you met our Computer Guru Larry :>D He hates his when his department gets cluttered with non-computer posts.
Details on cleaning the filter in the link.
https://www.google.com/search?q=wfw9550wl00+clean+filter
Posted on Jul 29, 2021
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
My front load whirlpool washing machine got to spin cylce and stopped. The door wouldn't unlock and the light showed add garments but it hadn't finished spinning the others any suggestions?
Your drain pump filter probably needs cleaned. YouTube has several videos you can watch on how to do it. It's an easy fix. Type " whirlpool duet drain pump " into the search bar. Let me know if you have trouble.
1helpful
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
2helpful
Whirlpool model # GHW9400PL2 solution for the FO2 error indicator
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
3helpful
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
7helpful
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Whirlpool Duet Front Load Washer
The following link will explain to you how to check the drain pump filter on a Whirpool Duet:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance Good luck.
Marvin
Marvin
Mike
