Health & Beauty Logo
Keith Allies Posted on Jul 03, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Florabest charger. The light has been on red for 8 hours and not changed to green.
Rob Hill
Level 3:
  • The Master 1,480 Answers
  • Posted on Aug 22, 2021
Rob Hill
The Master
Level 3:
Answers
1480
Questions
0
Helped
517467
Points
3838
Hi, one of two things,
Either the charger fully charged circuit has failed or it's not actually charging
or
the batteries in question cannot recharged ..
Regards
Rob
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
When the walkie on full charge the charge light is not going to off ?
If your battery is flat or close to, then a complete charge is ussually 23 hours. or thereabout, so this is why the light on your charger is still on. The light for a flat battery is red and when the battery is fuuly charges light is green.
8 hours of charging a flat battery, isn't enough, hence the light staying on RED, if I'm not wrong and I doubt that I am.
I hope this has answered your query.
Best regards,
Peter
7helpful
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
2helpful
3answers
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Top The Health & Beauty Experts
Paul Carew
Steve Sweetleaf
Steve Sweetleaf
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
