Question about HP Office Equipment & Supplies
Hp laserjet 1020 no print..?
Hp laserjet 1020 attention light is blinking and ready light is on and off few seconds there no print . please help. some times print, than you
Posted by Alejandro Leon... on
OfficeServiceAjnc
  • HP Expert
  • 215 Answers
Change the usb print cable.
Posted on Jul 02, 2021
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
My HP1020 giving me great headache that I can see the print job pending in the printing list but no print out. Once I sent in the print job, the printer's orange light blinking and it turns to green light...
Use the Print Diagnostic Utility. You can download it for free. Please follow these steps:
- go to www.hp.com on you web browser - click support and drivers - select "download drivers and software" - type your printer's model # or name (ex. Laser Jet 1020) - click search - you should be on the window which lets you select an operating system - select your operating system and click "next" - step 2 should appear - click utility - click HP Print Diagnostic Utility - click download - run or save the file (i recommend you to save the file)
My hp laserjet 1020 plus printer blinking both lights when i give print but no papper picking and printing not coming just blinking both lights what is the problem and what is the solution
the problem your printer is facing is due to some foreign objects present in the printer area so i would request you to give the printer for service rather than taking any chances
Attention Light Flashing
Unfortunately, HP didn't make this indicator very descriptive. Their product specification page for this printer states that the blinking Attention light, "indicates that the printer media input trays are empty, the print cartridge door is open, the print cartridge is missing, or other errors".
You've already changed the print cartridge and the light is still blinking, so you should take a look at the other conditions described such as an empty paper tray, open door, and so forth. You also will want to look for a paper jam or carriage jam. These are two very common errors that will result in a blinking Attention light.
HP.com does provide a web page that describes a specific problem associated with a blinking Attention light:
Job Stuck in Queue
See if any of these suggestions work out for you. If not, post back your results along with anything else that you've learned about the problem. Good luck.
Open Questions:
0answers
HP Designjet 1050 / 1055 CM green tint Problem: -------- HP Designjet 1055 CM Postscript: Black and gray-levels printed with green tint Description ----------- My HP Designjet 1055CM PS prints gray levels and black color with green tint. Somehow, the printer does not mix C-M-Y to get the proper color tones. Just to check if using the pure black ink tank as a reference, I tried to force the printer to use it by sending the following simple Postscript test-file to the printer. -------------------------------------------------------------- %!PS-Adobe-3.0 EPSF-3.0 > setpagedevice %%BoundingBox: 0 0 1500 200 newpath 100 70 moveto 0 100 rlineto 100 0 rlineto 0 -100 rlineto -100 0 rlineto closepath gsave /DeviceCMYK setcolorspace 0 0 0 1 setcmykcolor fill stroke showpage --------------------------------------------------------------- It should draw a 100% black rectangle. The test.ps was sent to the printer with the command 'lpr -l test.ps ' The -l should force the cups printing system to send test.ps in raw format i.e. without any preprocessing by the printing system. The processing should be done completely within the PostScript RIP of the printer. However, the print has the exact same green tint as if I print through any application. How can the printer be forced to use the black cartridge? Any idea how to get rid of the green tint? My Mac is running macOS Monterey 12.6 Apart from the green tint issue, the printer is working fine. Any help is greatly appreciated! Best regards!
Ben Johnson
Marvin
Marvin
