We have a Frigidaire Gallery air conditioner (the kind that looks like a cooling tower) and we can't lower its temperature. We lower it, but it pops right back up to what it was before.
Thats normal its showing ambient when you lower it the number will change to the setting and then will go back to show what the ambient temp as the room gets cooler the temp number will go down and shut off at set temp
Amazon.com, Inc.
Rating: 4 - 4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
I understand your Frigidaire air conditioner, model# FAS296R2A, is not cooling. I also see that, both the filter and condenser are clean. First, try setting the temperature lower. Secondly, the compressor could have shut off by changing modes. Set to the "COOL" setting and wait about 3 minutes for the compressor to restart. Lastly, check the temperature sensing element, located behind the air filter, to make sure it is not touching a cold coil. If it is, straighten the sensor away from the coil. I hope this is helpful.
I understand that your Frigidaire air conditioner, model# FAC107P1A, comes on with the compressor running, but the air is not cold. First, check to see that the temperature sensing element, located behind air filter, is not touching a cold coil. If it is, straighten the element away from the coil. Secondly, try resetting to a lower temperature. Lastly, the compressor may have shut-off by changing modes. Wait approximately 3 minutes and listen for compressor to restart when set in the COOL mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
I understand that your Frigidaire air conditioner, model# FAC124, is not blowing cold air and there is no water draining out. First, try setting the temperature to a lower temperature. Secondly, make sure the compressor did not shut off by switching modes. Make sure it is on cool and wait approximately 3 minutes and listen for the compressor to restart. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
I understand that your Frigidaire air conditioning, model# FAC126P1, is not cooling. First, try setting the temperature to a lower temperature. Secondly, make sure the compressor did not shut off by switching modes. Make sure it is on cool and wait approximately 3 minutes and listen for the compressor to restart. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
Lowering the temperature setting doesn't change the temperature of the air coming out of the unit it just lets it run until the room temperature gets colder. Check the temp of the air coming out of the unit. If it isn't as cold as it used to be the charge could be low. First though you should make sure the filters are clean and the coils.You should also check the actual room temp. It's also possible the unit doesn't have enough capacity to keep up with the cooling load of the room.
