Question about Lexmark Office Equipment & Supplies
My lexmark x860de fuser error 921.00
My lexmark printer x860de fuser error 921.00.i replaced fuser but still showing same error pls help....
OfficeServiceAjnc
  • Lexmark Expert
  • 215 Answers
To reset the maintenance count 1. Turn off the printer 2. Press and hold the 2 and 6 buttons simultaneously. 3. Turn on the printer. 4. Release the buttons after 10 seconds. The Configuration Menu appears on the LCD. 5. Touch Reset Maintenance Counter from the Configuration Menu. 6. Reset Maintenance Counter appears in the header and Yes and No appears below the header. 7. To cancel the reset operation, press Back or No. All other button presses are ignored. 8. To initiate the reset operation, select Yes. The maintenance count resets to zero and the LCD returns to the Configuration Menu
Posted on Jul 02, 2021
Testimonial: "Tanks for help. But problem the 6and 2 is not working. 6and 3is working.."
Lexmark t644 is showing "920.06
920 error is cold lamp on fuser replace fuser will clear problem
2helpful
1helpful
The printer just finished printing 7 pages and it clicked and the showed 122.05 Service fuser error.
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $300 for a new one, so I think you would be better off getting a new printer unless you find a second hand fuser on Ebay. They usually send for under $100.
6helpful
I have a Lexmark c540n printer that has the fuser error of 122.03 service fuser error how do i clear it on my machine I don't have tick btn any help would be great
you can reseat the fuser, and see if the message goes away. Or you will need to replace the actual fuser assembly. unfortunately you can't just remove/clear the error. see picture attached as this is what the fuser looks like
after you replace it let me know if you still receive the error.
3helpful
Lexmark x544 122.05 service fuser error
Service Fuser Error shows when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
2helpful
123 Service Fuser Error - Lexmark C762 Colour Printer
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
My Lexmark Optra S 1855 is showing a fuser error. What needs to be done?
the fuser needs to be replaced its about 200 dollars just search for Fuser for the model of your printer
Thank You John C
3helpful
Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Open Questions:
Top Lexmark Office Equipment & Supplies Experts
Marvin
Marvin
Mehandi Husain ...
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
