I see other people ask and people link how to take apart other Maytag dryers and it's not the same please help
Well you don't say WHY you want to take it apart Chase? Generally if you Google
make model replace element
it will get you as far as you need to go. You should be able to work it out. If not, get a professional to do it.
Videos
https://www.google.com/search?q=maytag+bravos+medx700xw+replace+element
Testimonial: "To replace the drum itself I'm curious how to get the top and front off. Are you able to provide any information on that?"
Because even with a google search of what you recommended it does not show the Maytag I'm speaking of it shows one with the element in a different location
If you need to replace the drum, I would say it is time to replace it with a new dryer.
Turn off Breaker or unplug.
Pull the machine out from the wall. Remove the screws that hold the top Controls Section.
Remove the screws that secure the top of the dryer and take the top off.
Remove the screws at the bottom front at the base plinth.
now remove the front panel and door.
Disconnect the Door Switch
At the rear, you now need to remove the rear drum bearing.
Remove the belt by slacking off the idler wheel and slip the belt off the motor.
You can now lift the up at the front and out.
All the information above from memory when I had two Maytag Speed Queen dryers 20 years ago in England. I owned a hotel so they got a lot of use. I serviced them every year, also replaced a motor, front drum sides, belt and rear bearing. I never needed to replace a drum! :>)
https://www.ajmadison.com/cgi-bin/ajmadi...
