Question about General Electric Washing Machines
General electric Washer gtup270em0ww
I have general electric washer gtup270em0ww, it's not keeping the water when i start it, the water comes out all the time. Can anyone show me the part i should change? Or any way to fix it?,, thanks
  • aiwodniw12
    aiwodniw12 Jul 12, 2021
    Stay away from GE (owner by Chinese firm Haier) and Samsung. Whirlpool, Maytag, and Kitchen Aide (along with Jenn Air and Amana) are ALL the same company. Many parts and components are the same across the different brands and models. I'd go for the $450 Amana if it were me. Soon the Speed Queen brigade will arrive, down vote me and tell you to buy a terribly over priced speed queen, but do your due diligence, see what consumer reports has to say. Besides the cheap Amana (all these brands machines tend to last less than 7 years), the LGs tend to get good marks.https://kodi.software/ .https://nox.uno/
  • ADMIN Canada
    ADMIN Canada Jul 12, 2021
    Older Speed Queens were made in Louisville, Kentucky. And aiwodniw12, you only appear to be here to Spam, so any advice is seriously undermined.
ADMIN Canada
    Top Expert:
  • General Elec... Master
  • 41,770 Answers
Pumping out or leaking out?
There are various rubber connectors underneath and they can perish and leak. There is a trick. slide a piece of paper under it. Switch on and after a minute, pull the paper out. It will give you a rough idea where the leak is, front, back, left or right. Then pull the machine out, and tilt it safely against the wall, get someone to hold it and look with a flashlight for the area where the wet patch on the paper was.
Parts
https://www.google.com/search?q=ge+gtup270em1ww+parts
Posted on Jul 12, 2021
Wbvh5100hww washer - no error codes. Starts to fill, then goes straight to drain and skips other cycles. Test mode t08/t09 for hot and cold water valves fails.
There is a strainer in the hoses that are most likely clogged; clean it out and your problem should be repaired. If you still have the errors and you have good pressure coming to the washer, then you will need to replace the water valve on the washer. Here is that part to order. Keep me posted.
4helpful
2answers
F and H keep coming up on screen
The information provided is general. For information specific to your washer please resubmit the question, including the model number.
The "F" is at the beginning of all error codes. This indicates the a Fault has taken place. The second number or letter indicates what the Fault is.
FH : Is displayed when no water has been detected entering the washer.
If the control has turned on the fill valve and after 8 minutes the flow meter has detected 10.5 gallons of water and not detected a pressure switch trip, the valve will be turned off and the failure code will flash in the display
Unplug the washer from its electrical source and wait for 30 seconds.
Replug the cord into the electrical source and try to start a normal cycle or a cancel drain cycle.
The machine should start the pump out mode and empty the water.
If, after 30 second, the machine has not detected water entering into the machine, the valves will be shut off and the failure code of FH will be displayed.
Check all hose connection and valves, both hot and cold, are turned on completely.
Verify that water is at the fill hose connections at the back of the washer.
The main control has sensed a component failure in the machine and will be needing a diagnostic visit for a possible repair or replacement.
Hope helps (remember to rating this free answer and leave a comment)
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Washer does not go into a spin cycle.
Good morning. To start off with, get a shallow pan. At the bottom front of your washer, there is a filter trap. If its not visible, you will have to remove the kickplate held on by three screws at bottom. Slide shallow pan underneath and up to frame. Slowly turn counterclockwise until water starts to come out. When pan is midway full, empty. Repeat this procedure until no more water comes out and unscrew filter and pull out and clean. Reinstall snugly and install kickplate if it was removed. Have a good day.
1helpful
Door leaks water
funny on these washers they used a piano hinge for the upper and lower hinge often they get bent real easliy and sometimes you have to replace the front panel
No water coming out
Clean out or replace the tube running from the water level switch in the backsplash to the washer tub. It tends to plug up with gunk right where it attaches to the outer tub. When it gets plugged, the washer can not tell if the tub is empty or full.
2helpful
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
No hot water into washer
In your problem you describe that you are getting hot water are you getting cold water too?. Make sure on the water valves are on the full open setting to eliminate a water pressure diffrence and any other valves connected to those water lines. If that checks out check for clogs in the hoses and filters that could be backed up. If that dosent fix the problem then its in the washer either the hot/ cold regulators or the timer.
This is for GE WBSR3140DW Top Load Washer
Heres a link to help to find the correct parts.
http://www.partstore.com/Model/General+Electric/General+Electric/WBSR3140DW.aspx
Hope this info helps to anyone who reads it.
Washing Machines Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
