Why one of my app on windows 10 started working only in Administrator mode instead of normal mode ?
One of my App " Free Cam" Screen on windows 10 started working only in Administrative mode, previously it was working fine, when I try to open it nothing happens, Kindly help me in this regard ?
Posted by Piyush Bhardwaj on
  • 1 more comment
  • Larry Ng
    Larry Ng Jun 24, 2021
    log out and log back in, correctly
    same answer from xp to now.
    when apps are installed, it asked for" just you "or every users, accounts?
    so if wrong now, in-Install that app then re-install it back correctly
    or be logged in correctly first.
    also learn some camera are for security, and as such are locked in to only 1 user.
    they do that (if do) to have max security. see?
    case in point dad does not want wild young boy to use CAM settings.
    see?
  • The Spaminator
    The Spaminator Jun 26, 2021
    read this as wellhttps://support.microsoft.com/en-us/wind...
  • Anonymous Jun 26, 2021
    Piyush the OS can be infected.
    reload the app yet"?
    talk to your Free Cam , product maker yet for help, it is their app after all.
    is this it?
    https://www.freescreenrecording.com/
    if yes, You do know Free CAM is crippleware RIGHT>
    proof is here
    https://www.freescreenrecording.com/cam-...
Don A
  • Computers & ... Master
  • 2,880 Answers
The following may help as you encounter programs requiring being run as administrator. It is not a replacement for Larry Ng's more direct addressing of your situation but may come in handy..
https://answers.microsoft.com/en-us/windows/forum/windows_10-performance-winpc/how-to-stop-new-applications-from-requiring-to-be/031890f9-7155-43a4-875d-f1d50c8713aa
Posted on Jun 26, 2021
1helpful
PHOTOS APP NOT WORKING IN WINDOWS 10
Hello Royal ror, you can use 5 easy and basic solution tricks.
Update WindowsUpdate the Photos appRestore libraries to defaultDelete outdated registry keysRun app troubleshooterAfter that you still face same issue, just hit me at +1 (844) 355-5111 (Toll-Free) number.
Cheers,
John
tip
20 useful Microsoft Windows 8.1 Tips
Shortcut Action
Windows Key + S Open Search Charm to search Windows and Web
Windows Key + Q Search within the opened app
Windows Key + F Search files
Windows Key + Z Get Commands and Context Menus within an app
Windows Key + . + Right Arrow Snap app to the right
Windows Key + . + Left Arrow Snap app to the left
Ctrl + plus (+) Zoom in on Start Screen
Ctrl + Minus (-) Zoom out on Start Screen
Windows Key + Down Arrow Close an app
Windows Key + Start Typing Search your PC
Windows Key + O Lock the screen orientation (portrait or landscape)
Windows Key + Ctrl + Spacebar Change to a previously selected input language
Windows Key + P Choose a presentation display mode
Windows Key + X Open Start Button options
Windows Key + Home Minimize all but the active desktop window
How do i recieve and make phone calls using huawei mediapad 10link?
For enabling your voice call on Huawei MediaPad 10 FHD follow this instructions :
1- First you should root your device follow the bellow instructions :
Root On ROM 4.1.2
Root On ROM 4.0.3
2- Download Root Explorer android app
3- Insert an empty microSD card to your tablet (100Mb is enough!)
4- Open Root Explorer app and go to this location :
cust/hw/normal/prob and local.prop
open it in edit mode then :
Search this content:
# ro.config.hw_phone_switch=0
And then change it to this (remove # and turn 0 to 1):
ro.config.hw_phone_switch=1
And then search this content :
# ro.config.hw_phone_ui_hide = false
Change it to this (remove only #)
if you don't see them write yourself on file at the end of file named local.prop :
and then save local.prop file .
5- Connect your tablet to Pc and download this phone patch and extract it
Download Phone Patch
Open (Run as administrator) the file with the name Huawei MediaPad FHD 10 3G_4.1.2 official version of the B002 a key ROOT.bat and it shows to you two messages ,on both of them click ok and during the run, your tablet reboots on fastboot mode.
7- After your tablet goes off and on PhonePatch2 app will be add to your apps open PhonePatch2 app , First press the gray button and wait for the message to be rooted to the access request and confirm , Second press the second button to install the phone app and then restart your tablet after installation.
8- Ok you can uninstall PhonePatch2 app and enjoy from your Huawei MediaPad 10 FHD !
Attention :
If Phone app is on apps list but you can't dial a number from PhonePath2 click on second bottom again to install the phone app again .
Enabling voice call have been tested successfully on this two firmware
Mediapad 10 FHD 3G with firmware S10-101L_FIRMWARE_Android4.1_C001B002SP01_General_Vers ion_05011GJG { LTE ROM}
Mediapad 10 FHD 3G with firmware S10-101u_FIRMWARE_Android4.1_C001B011SP15_3G_General_V ersion {Latest version Until Today 1/3/2015}
Can cyber chess download to windows 10?
Hi , do you mean that the subject program will not install using Windows 10 operating system ?
If so , try running the app's setup program located on the install disk media in compatibility mode for an earlier Windows version such as XP sp3
Compatibility mode enables a late version native Windows to run a program as per a user designated earlier version Windows and so extend support for obsolete apps that may not run using default settings
Navigate to the install disk's file directory using Windows Explorer (not the browser) , click on the folder to open and scroll down to the setup ( application) file . Right click to open the context menu and select properties > compatibility : check : run this program in compatibility mode and select from drop down list XP sp3 (my guess) or latest published supported Windows version for the subject app.
Check under privilege level : run this program as an administrator
click apply > ok then close and double click app's setup file to launch installation
Hopefully will now install and app will subsequently launch and process correctly.
Get a full screen on face book please
Suggest to first try logging into Facebook using the browser on your tablet instead of the facebook app. If that display is normal in size ... it's probably easiest to
(1) uninstall the Facebook App (Control/Settings/Apps);
(2) reboot the Tablet;
(3) Restart the Tablet and Go to the Google Playstore ...reinstall the Facebook app.
2answers
How to split screen on Windows 8.1 using one app?
I guess you need to open the one app two times. Then carry out the split screen procedure. See link for clear details off this
How to Use Split Screen Mode in Windows 8 1
3helpful
2answers
Forgot password
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
1helpful
2answers
I have windows vista. I am trying to install ansys 11 on my laptop but the installation never starts. It stops on the page with install shield wizard. I downloaded a newer install shield version based on...
make sure that the install runs under administratives privileges, when executing an app that requieres admin rights the UAC will prompt to run the app under elevated rights, also you could try the following:
right click over the app installer
click on properties
go to the tab compatibility
check mark the box for ( run this program in compatibility mode for)
select windows XP SP3
also check the box that says ( Run this program as Administrator )
click apply and then ok
try to run the application now.
some apps won't run in vista unless a compatibility mode is set, but if this doesn't work you may want to try looking for a installer compatible with vista.
Computers & Internet Logo
Ekse
