Hello, it depends on how you have your PS2 connected. If you are using the component cables, check in the system settings and check if its in regular RGB. If you use the regular Yellow, Red and White cables, it should be in RGB mode.
Go into settings and put on game and comp input
It might be the av cable that is causing your PS 2 console to be playing in black and white. I would try and use the standard av cable hookups for your PS 2 and see if it makes a difference. If it is still in black and white then it could be there is something internally wrong with your PS 2 console.
