My TV doesn't connect to the internet so I have to update it manually with usb but no matter how much i browse i can't find the update file anywhere
It's software, not firmware. It's not available from anywhere except Sharp. You need to access your country support page first.
https://global.sharp/support/download.html
Page 60 of the manual. Note you should only update if there is a specific problem. Everything you take these executable files, there is a chance that you turn your device into a paperweight.
https://www.manualslib.com/manual/819109/Sharp-Aquos-Lc-40le820m.html?page=60
Testimonial: "thank you so much for your answer! I checked that global.sharp website but when I select the country it gives me an error (""Oops! That page can’t be found.) I really wanted to be able to connect my wireless headphones to the TV via Bluetooth without the need for an additional device, but I did not find this option on the TV, so I decided to update the software, maybe this feature will be enabled for me. But I guess your suggestion is that since there is no particular problem, I should not update it, right?"
The information you sent through to me was perfect. Thank you for being so helpful.
If you television had Bluetooth it would have been a selling point when new. The board would need a Bluetooth chip and aerial transmitter on the board. It is not something that you can add with software. The only way you can do it is with a Bluetooth dongle.
https://www.bestbuy.com/site/aluratek-bl...
This may work, but not guaranteed that your USB Socket has audio to it.
https://www.amazon.ca/Bluetooth-Transmit...
Set specs
https://www.bhphotovideo.com/c/product/7...
You are very welcome. Thanks for the Feedback :>)
