Question about Philco Audio Players & Recorders
Philco Turntable platter repair
I have a small philco record player. Recently the platter has been having friction, not making full smooth rotations. I took it apart to have a look around, and it almost seems as though the platter has dropped too low somehow, and when I manually push the platter from the bottom up, it's capable of normal rotations. If this is the proper solution, how do I manage to get the platter to actually stay up?
How install belt on philco 841 205 turntable
There are plenty of instruction videos on YouTube about belt replacement, look at a few of them, if you can't find the specific make of your deck.
9helpful
3answers
I have the Philco suitcase Turntable CD player. Art No. 841.237. When I got it from my friend, she hadn't given me the ac adapter/power source. When I got it, I assumed she had given me the right one. I...
I don't know whether your philco is the same as my crosley, but I recently had an issue where the record player stopped turning and it bamboozled me to no end. After digging up the manual online, I found out that you had to lift up the tone arm and move it to the right (past the holding clip) until it clicked, and voila, the record player started spinning again.
I hope this helps!
2helpful
How do you get the turntable to start turning? We just got a Philco turntable and can't find a switch to get the turntable to turn. We got it used so don't have the instruction manual.
A lot of turntables start moving when the arm is moved to the record start. The turntable should move when you move the arm to the edge of the platter, even with no record. If it doesn't, listen to see if the motor spins. Then lift up the platter matt to see if the belt has slipped off.
6helpful
How to turn on turntable on Philco Turntable CD Player
Just pull the arm back a little bit, the turntable should then start.
10helpful
2answers
2answers
Philco turntable cd with cassette player all i get is the cassette playing nothing else works where can i get it fixed here in washington state
just find a local electronic repair shop near you
look in the phone book for electronic /electronic repar shop
i have had to repair these before and the selector chip has failed because of a resistor letting to much current and voltage go into the chip , repair cost $40-$50 depending on the dammage
BELT FALLS OFF
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Turntable won't turn
In the middle of the TT youll Find a C-Clip It needs to be Removed before the Platter can be removed,You either have a Broken Belt,Or the Grease in the Guide is Old and must be Cleaned out and Relubed
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
