Televison & Video Logo
Question about Sony BRAVIA Televison & Video
I have a Sony Bravia 55 inch 4K tv. Set up a new sony soundbar and subwoofer HT G700. The soundbar is working but there is a message flashing on my tv screen. How do I stop this annoying display?
Message is Audio system has been connected. If there is no sound, connect the system to "HDMI 4/ARC".
Nasir Muhammad
    Champion:
  • Sony Expert
  • 252 Answers
  1. Hello
  2. please connect your sound bar with HDMI1 which is ARC and you can control your sound bar with one remote.
  3. thanks
  4. M Nasir
Posted on Jul 12, 2021
1helpful
How do I connect my Sony soundbar ht-ct 260h to my blu ray player etc, I have no optical port or arc hdmi port,at the moment connected through the audio lead to soundbar & tv ?
hook your dvd player up to the tv via hdmi, then take the optical audio output from you tv to the soundbar. Make sure to enable to audio output jack in the tv setup menu as some manufacturers disable this jack by default.
2answers
What causes my sony bravia dlp tv not to come on?
Sounds like it needs a new power supply board.
Here's one: http://www.shopjimmy.com/sony-a-1310-234-a-be-board.htm $69.32 USD
Easy to replace, just open the TV up, unplug and unscrew the old one, pop in the new one!
1helpful
2answers
I have a Sony Home theatre 5 disc changer, DAVHDX975WF and a BDPS560 Blue-ray player connected to a 46" LCD TV KDL46XBR10. The HT has been the speakers for the TV since day one. The Bravia Sync...
it is most likely bc of a firmware update. i have heard of this problem while working at best buy. rarely do i see the bravia link actually fail. i would shut both off for a little while and connect them without the link then connect the link. kinda like a reboot of the whole system . hope this helps!
I have a sony bravia 55 inch rear projection tv. model no. KF-55E200A. when i turn it on it flashes green like normal but then starts flashing red. can you tell me what is wrong with it please
Most probably it is an optical block issue. You can contact sony customer service to setup the free service.. If you need the contact infomation, please let me know where you're.
www.fixya.com/users/shajanrs
3helpful
How to set up a soundbar with a subwoofer. Where to place the subwoofer. Does it need to be behind us? Is it ok if its in a corner? Will it sound as good if it is in front of us next to the tv?
The subwoofer deals with low frequencies, which are not very directional (ie, it's harder to tell where the sound is coming from).  So where you put it isn't critical to the sound, provided that it's not behind curtains or something that will soak up sound.  The bigger speaker you have in your subwoofer; the less important the position is.
Putting it in a corner is something you're going to have to try, but you may even end up with better bass if you do, as a corner can act as a soundbox and emphasise bassy sounds.  Conversely, your subwoofer may not like being in a corner and interference effects from the sound reflections could degrade the sound.  Like I say, try it and see what it sounds like.  It depends upon your subwoofer, what else is in the corner, precise positioning, and how reflective to sound the corner is.  If it sounds terrible, move it a few inches and try again.
You can put it in front of you next to the TV, no problem.  The only downside it it's a big ugly box.  My wife always makes me hide my subwoofers behind something.
1helpful
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
3helpful
Sony HT-CT100 soundbar + STR-DG720 = Yes misery, no audio
It's not going to do whayt you want. On the premise that you can't run a dedicated receiver to a dedicated receiver. One processor is not going to override another. The soundbar is a "self contained" closed system. Much like Bose products. I understand what you are looking for, it just can't be done with this product. Options: replace the sony soundbar with a passive polk soundbar or similar and keep the AV receiver or: Return the AV receiver and use the nice, but limited sony amplified soundbar. Hope this helps
2answers
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
Open Questions:
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
