A
Anonymous Posted on Jun 18, 2021
My canon printer mp250 connected to my laptop but when I try to print it says printer is paused ?
Alvin Barnabas
Level 2:
Habit-Forming:
  • Expert 136 Answers
  • Posted on Jun 18, 2021
Alvin Barnabas
Expert
Level 2:
Habit-Forming:
Answers
136
Questions
0
Helped
59470
Points
233
Go to Cannons web site and try to download the current driver, or use the installation disk that came with the printer, reinstall the software. Connect the printer to another computer/laptop. install the software and ssee if you get the same response. If you get the same response your printer is faulty
My Canon MP250 says it is offline- but there is no option of resuming the printer in the system preferences (MacBook Pro)- What other solution(s) could there be? I've tried restarting both devices
Go to System Preferences > Hardware > Print & Scan > click on add printer or scanner. Now let the OS search for printer under Default tab.
If it finds your MP250, great. Proceed with adding and delete the old MP250 printer in the list.
5helpful
3answers
Canon pixma mp250 showing fault code e05 will not print
Try to stick with original cartridges... Generics only waists time and money
I cant connect my acer iconia tab with canon printer MP258
Press START - Control Panel - Printers and Faxes - double-click Printers and Faxes. Perform checks on:
1. The printer must be in a position Set as Default Printer (see picture)
2. Status = Ready (see picture)
3. Docs = 0. If there is a number 1 or 2 or 3, cancel all the print command, by the way: double-click the Canon MP250 Printer series - click Printer - click Cancel All Documents
4. The printer must be in a position online (see picture)
My Canon PIXMA MP250 Inkjet isnt working?
Does the printer power up?If not,check the power cable or probably replace it.
If it does power up,disconnect everything including the usb connections and also turn off your PC.
Wait a while and then re-connect them all.Start the PC first and then turn on the printer.
Now try printing.If still cant print:-
  • You might have run out of ink.Check the cartridges and replace any dry ones.
  • Check for paper jams on the paper paths and manually remove any stuck papers.
Hope this helps.Thanks!
3answers
My printer keeps saying it's offline what could be wrong?
Canon is a Japanese brand that has spread its wings all over the world now. It is recognized for the manufacturing of cameras, camcorders, steppers, photocopiers, & medical equipment.
Similar to any hardware, even a printer has faults and problems while interacting with a different system. One of these issues is that it shows "Canon Printer Offline" even when it is properly connected.
Solution's of Canon Printer Offline:-
Solution 1: Restart the Printer Spooler service.
Solution 2: Disable Use Printer Offline feature of your Canon printer.
Solution 3: Reinstall your Canon printer software.
If, you are getting a Canon Printer Offline error to feel free Chat with Technician. If you are using a canon printer, it is possible that your printer cannot print correctly and then you find that its status is offline.
Contact Expert - Canon Printer Offline
Every time i try to print it says the printer is offline cannon mp250 windows vista
Press your start button in the bottom left corner of your screen. In the search bar search for devices and printers. Find your printer on the list, if there is a duplicate right click the one that is not set as default and click set as default printer. If this doesn't work go here and download the driver for your printer!
http://drivers.softpedia.com/get/PRINTER/CANON/Canon-PIXMA-MP250-Printer-Driver-102.shtml
7helpful
My canon mp250 shows the error 5200 when i try to print what does thet mean ?
it means Print head temperature rise error or Error Code 5200
Condition: The print head temperature exceeded the specified value.
Problems and Solutions:
  • Turn off the printer and then turn on if error still persist replace Ink cartridge or print head
Visit:
[url]http://pcmediks.blogspot.com[/url]
CANON PIXMA MP250 UBUNTU 9.04+ CONNECTION
Canon Inc. made available (finally!) official drivers: 1) for printing cnijfilter-mp250series (v3.20-1) and cnijfilter-common (v3.20-1); 2) for scanning scangearmp-common (v1.40-1) and scangearmp-mp250series (v1.40-1). You can download their from http://support-au.canon.com.au/P/sea..._os&g_os=Linux
also don't forget that manuals will be useful: http://support-au.canon.com.au/P/sea...=0&menu=Manual
Reference http://ubuntuforums.org/showthread.php?t=1314209
5helpful
2answers
Mp250 canon user intervention required problem
Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
old marine
old marine
ZJ Limited
ZJ Limited
