Question about Vizio Televison & Video
Vizio S3821w-CO sound bar
Bllnking led, no sound, power supply is ok,does it need an eeprom?
Posted by Walt Schuman on
1helpful
Vizio E371VL power on logo on screen and back lights on for 1-2 seconds then off but have sound has a new power supply board ideas?
Because you have a new power supply installed, then, In most of the case, the EEPROM on the main board is damaged, you may replace the EEPROM, or get a new main board.
Vizio sound bar remote buttons
https://www.google.ca/url?sa=t&source=web&rct=j&url=http://cdn.vizio.com/documents/downloads/accessories/S3821W-C0/QSG_S3821wC0.pdf&ved=0ahUKEwjav96JzufWAhWp3YMKHVUyCr0QFghHMAo&usg=AOvVaw1tG0BTeyfXoyKxQuyJpRDI
2answers
What are the symptoms of a bad psu for vizio m550nv
Vizio 0500-0612-0030 Power Supply / LED Board for M550NV
www.shopjimmy.com/vizio-0500-0612-0030-power-supply-...
ShopJimmy
$77.42 - ‎Out of stock
This Vizio 0500-0612-0030 Power Supply / LED Board for M550NV (0500-0612-0030) works for these ... The odds we'll get it soon: Bad (What does this mean?).
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply ...
electropartsonline.com/vizio-55-m550nv-0500-0612-0030-lcd-power-su...
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply Board Unit Motherboard. ... Any tears or bad connections between boards must be replaced FIRST. 2.
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair ... I can not get it to power on so I ...
Vizio 70 smart led TV sound OK no picture very dim light on
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Remote for vizio sound bar model S3821w-CO not working it has new batteries lnstalled.
You may have to check for a loose connection with the battery contacts. Today's solder is a joke and these physical points are subject to poor connections. Also try another set of batteries.
Vizio help
Not sure the issue. HDMI from cable box to TV. Same with Vizio.
The soundbar usually connects to the optical out from the TV to the in on the soundbar. Subwoofer has to be paired to the soundbar. Instructions should explain or maybe find online by manufacturer
1helpful
3answers
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
