As soon as unit powers it shows this code
My dehumidifier is displaying an error code. What does it mean?
Your dehumidifier has sensors to monitor for various conditions that may prevent the unit from operating in a normal manner. Please refer to your user manual for error codes and operating instructions for your specific model. Common dehumidifier error codes and messages can be found in the list below:
ES or E1 - Temperature sensor error
E2 - Defrost sensor error
AS or E3 - Humidity sensor error
P1 - Unit is in defrost mode. Defrost process should take a minimal amount of time before the unit returns to proper functioning order. If the unit display P1 code for more that 1 hour, unplug unit and allow to manually defrost for 4-6 hours.
For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service.
EC - Ambient temperature error. The environment where the unit is operating is either too cold or too warm. Make sure the ambient temperature is suitable for the unit (41°F - 95°F).
LO - Temperature too low error - Current room temperature is below 32°F. Make sure the ambient temperature is suitable for the unit (41°F - 95°F).
HI - Temperature too high error - Current room temperature is above 122°F. Make sure the ambient temperature is suitable for the unit (41°F - 95°F).
P2 - Bucket is full. Empty the water bucket and reinstall it. How do I drain my dehumidifier?
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
