Question about Tablets & eReaders
NXA8QCX116 no data from usb port on tablet , data cable works fine.
Posted by miguel garcia on
  • The Spaminator
    The Spaminator Jun 18, 2021
    Hi miguel garcia, we want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    what usb port interface does Tablet have ?
    USB 1.0 , USB 2.0 or USB 3.0
    what usb port does the other device use ?
    https://www.noterepeat.com/articles/pc-t...
Aron
  • 1,963 Answers
The USB port could be having problems on your tablet and it should be fixed from someone that repairs tablets and Ipads and Ipods.
Posted on Sep 15, 2021
How do I back up my tablet info
if you tablet has a usb port connect it to an external storage unit
if it doesn't then many charge cable are usb cables and can transfer data as well to an external device
1helpful
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Charging port not working. How can I fix it
If it's a mini-USB charging port you could have damaged contacts on either your USB cable or the USB port itself. You should try another cable first hoping that it's only a damaged cable. If the new cable doesn't do it then it's probably the USB port itself. If that's the case, you probably have to take or send it in for repair.
1helpful
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
2answers
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
2answers
How can I fix the RCA 7in power port?
You should contact Authorized Dealer or Service Center to get it serviced.
Why my computer can't detect my galaxy tab
There's several things that could be the cause here. I'm going to assume that you're plugging the tablet into the PCs USB port with the standard charging/data cable that came with your tablet.
Easy Solutions:
  1. You might have a bad cable. Try a different cable, if you have one.
  2. Your USB port might be bad - try plugging into a different USB port. If you're plugged into the front of the PC, try the ones on the back. Also try plugging a different device into the USB port that you were having trouble with - does the other device work in that port? If so, your USB port is OK.
  3. Go into the Settings app on your tablet. Select Storage and tap the menu (three dots in the upper right corner). Select USB Computer Connection from the menu. There will be two choices here: Media Device (MTP) and Camera (PTP). Try unchecking whatever one is checked and checking the other one. Unplug your tablet and plug it back into the PC.
More Challenging Solutions:
  1. You might not have the proper drivers for your PC to recognize your tablet. Samsung makes a software package for your PC to communicate with your PC called Kies. You can download Kies here: http://www.samsung.com/us/kies/ Download it and install it. Then plug your tablet into your PC and it should find it.
  2. There are other ways to transfer files between your PC and your tablet, some of them are really easy, some not so much. The easiest is the Dropbox app. Download the app from the Google Play store - it is free. Create a free account and sign in. Then on your PC go to www.dropbox.com and download their free Windows program. Install it and sign in with the same account info that you used on your tablet. This creates a shared space out on the Internet. Anything that you put in your dropbox folder will automatically get put in your dropbox folder on your PC. On your tablet you can look at what is in the dropbox folder and choose whether or not you want to copy it to your tablet. You can also upload files from your tablet to the dropbox folder (automatically putting them on your PC).
  3. Another way to transfer things between your tablet and your PC is the AirDroid app. You can download it from the Google Play store - it is free. When you use it on your tablet, it will give you a web address on your local WiFi. Go over to your PC and open a browser, go to that address and you can communicate directly with your tablet over WiFi. You can copy files, add and delete thigns, and all sorts of other functions. AirDroid is very useful.
Psion 5 mx series palm top
depending on where you are...go to "Incredible Connection/Matrix warehouse/computers r us" and ask them about a "USB-to-PDA cable"
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
