Question about Sony Televison & Video
I have a one single vertical line at the center of my Sony KV-SZ29M80
When I switch on the tv, it only shows a dim vertical line at the center of the screen. Sound comes clearly but no picture. Please I need your help.
Posted by christian agbotah on
    Top Expert:
  • Sony Master
  • 76,763 Answers
Absence of horizontal scan. Check and replace damaged component/s at its horizontal line output stage circuit. Check for any loose soldering at any of the components at this stage circuit. It is a common fault to Sony sets, that there happens some loose solder joints at this stage. Check for it too.
If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box.
There are some practical experience described by the author of second site. To get them collectively, just type in "my service table today" in the search box at the right column and press enter.
Posted on Jun 19, 2021
1helpful
Sony kv sz29m80
The fault is with its vertical scan output section circuit itself. An IC failure, or a loose solder terminal/s can cause this problem. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help. More than Ten Lakh viewers cannot be wrong.
5helpful
I nead a diagram sony model kv sz29m80
i need a schematic diagram for my sony trinitron kv-sz29m80. it was a one horizontal line
1helpful
Where is the vertical part of the Sony KV-XJ29M50, or what type of IC in that part?
Hello
Vertical output Ic is in the A board itsef. It is an SIL type [Single In Line type] Ic, screwed onto a metal heatsink to radiate heat out of it while working.
OK.
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Sony gv-27v42 27" tv picture cuts out after a few minutes
Vertical lines down the center only means that you have a loose connection on the Yoke. Re solder all the connection on the yoke and where the yoke connection meets the main board.75481bd.jpge307a54.jpg
best regards
Circuitcity
4answers
No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Sony CRT Tv (KV-T29SZ8)
When you see white lines at the top of the screen, it means that the pump-up capacitor next to the vertical output IC is bad and the IC is about to quit. When the output finally quits, you get a black screen with possible dim spots. The vertical output IC and its pump-up cap will have to be replaced, and the little fuse resistors next to the flyback in the + and - supplies to the vertical output IC must be checked too. If you have experience working on TV's then you can do it yourself, but if not then have the set serviced by a tech experienced in Sony sets.
1helpful
2answers
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
Televison & Video Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
