Ovens Logo
Question about Frigidaire Ovens
I am looking for a timer for a oven
Hello, I have a Frigidaire wall oven #CPEB30S8CC2 and looking to find a timer: 318010701 for it. Do you have this piece?
Posted by sara shahvar on
john h
    Top Expert:
  • Frigidaire Master
  • 27,936 Answers
Fixya doesnt sell any products --online search or appliance repair shop
Posted on Jun 24, 2021
What do the error codes for frigidaire elite electri clean oven
Hello friend, thank you for your post!
I see you have a Frigidaire wall oven and you are searching for error codes. Do you have a specific error code that your oven is giving you? Also, could I get your model number please? With that additional information I would be able to provide you more assistance. I look forward to hearing from you. -Matt
My friigedare oven is not working we checked the elemaents thay are ok
Hello Izhar, this is Z. I am happy to assist you!
I see that your question is listed under Frigidaire wall-oven (FEB30S5D). If both the broil and bake elements are not heating, I suggest resetting your wall-oven. This can be done by either unplugging it or flipping the household circuit breaker to the off position. I recommend waiting approximately ten minutes and then turn on your appliance. If this problem persists, then your wall-oven could possibly be experiencing a potential wring failure, or a communication problem with the EOC (Electronic Oven Control). It would be advisable to contact an experienced appliance repair tech to assist further.
1helpful
Adjustment for timer tone - Frigidaire Gas Range
Hi RDWSR, this is AP. Thank you for your post.
Regrettably, you are not able to adjust the timer tone on your Frigidaire wall oven.
2answers
I need a controls manual for a frigidaire LEEB30T9FEA. I have the Owners Manual and the Installation Guide but neither has how to use the controls of the oven.
Hello - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
2helpful
INSTRUCTION MANUAL FOR LEEB30T9FEA
Hello Brent Delong - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Where is thermostat located in Frigidaire wall oven?
Hello Brad,
The thermostat is a small diameter appx. 6 inch long round probe it looks like this
11_4_2011_12_23_15_pm.jpgTo test it for proper functionality ya need to use a multi meter capiable of reading ohms of resistiance...unplug the sensor from the wiring and place the meter leads onto the 2 wire ends of the sensor and at room temperature once the oven has been off check for between 1060-1100 ohms at the sensor if its good,if the ohms value is much higher or lower that 1060-1100 at room temp. the sensor is defective.
GENE
The LED display is barely visible. Both for Timer and Oven Temp.
Problem with Frigidaire CFEB27S2AB2 Electric Wall Oven.
My LED display on my clock has the 3rd number not showing up all the
light. Sample 10:30 the 3 on the top is not light. What is the problem
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 • Ovens
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Top Frigidaire Ovens Experts
Marvin
Marvin
David Shaub
nu267
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
