Televison & Video Logo
My picture has gone very dark, any answers please
Posted by Joan batterley on
Abdul Rasheed
    Master:
  • 567 Answers
LED backlight is messing up.
Posted on Jun 15, 2021
    Top Expert:
  • Televison & ... Master
  • 76,851 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis.
https://elektrotricks.blogspot.com/
Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box.
Dark but watchable screen
to give an idea a brand and model number are needed
Viewsonic N3240WB-E top 3'' of picture has gone dark
From the description one of the backlights behind the display is failing, and cost would not justify the expence, you are further off replacing the monitor
7helpful
Image in playback mode is flashing from white to black
You're seeing blown-out highlights. These are the portions of your pictures that have been overexposed so much that they've gone pure white, losing all details. This is generally considered a bad thing and the camera is warning you of that. This does not mean that it's a bad thing in your picture; the camera has no way of knowing what effect you're trying for. The proper fix is to reduce exposure to bring back the details in the highlights. This runs the risk of losing details in the dark areas as they go pure black, but that's generally considered not as bad. After all, we don't expect to see things in the dark.
That was the long answer. The short answer is: press up/down on the multiselector to cycle through the different views available.
6helpful
Dark picture on my Philips 50" DLP HDTV
You will need to replace the lamp. That is the only thing that will cause the picture on a DLP to go dark. Please take a few moments to rate my answer. Thanks....
Why has the picture on my tv gone too dark to
have sound but picture is too dark to watch on tv
2helpful
2answers
TV has dark streak on one side of screen.
Your TV has a bad light tunnel. This part is inside the light engine. A qualified tech will have to replace it, but the part is available. Once it is replaced the TV will be as goog as new. Please take time to rate this solution and let me know if I can be of further assistance
Dark or no image at all
CHECK THE LAMP IF THE LAMP LUSTER HAS GONE OUT OR THE FILAMENT AT DOWN PORTION IS BLACK THEN THIS PROBLEM HAPPEN
HitachI HD DIGITAL TV 53"
Good Day;
For dark picture check RP41 heater circuit, 1.5 ohm, may have changed value & clean spark gaps. Good Luck, big IRISH.
Top Televison & Video Experts
Marvin
Marvin
