Televison & Video Logo
Question about Samsung Televison & Video
Why does Samsung led flashes like strobe light.
I have a Samsung led model UN60H6203AFXZA and the problem I am having is the screen flashes like a strobe light as soon as I plug it in it starts flashing on and off. No troubleshooting required even if I do disconnect the cable that goes to the hdmi and other connections. LED's still flash. Do I just need to replace the power board?
Posted by Serg on
Dusty
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
If the screen itself is flashing, are you possibly hearing a clicking/snapping sound inside? I had this happen with the non-smart 6003 model and it was actually caused by arcing between the connecters of two LEDs strips. I could smell it as well if I placed my nose close to the open holes on the back of the chassis. I replaced my backlight LEDs and the problem was solved.
Posted on Oct 20, 2021
Abdul Rasheed
    Master:
  • 567 Answers
Check power supply regulation. Do not keep it on for too long as the flashing might damage the backlight LEDs.
Posted on Jun 15, 2021
    Top Expert:
  • Samsung Master
  • 76,851 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://elektrotricks.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right column. View it on a desktop or in web View. Mobile view has no search box.
Testimonial: "I tried the links you provided and they for some reason no longer work. I purchased another power board and the led’s continue to flash. The small red light by the On/OFF button flashes twice stops."
Samsung TV - lights flicker and no standby light
Hi Ashley....Chances are your LED backlights need replacing, if you see a flash then black screen some of the lamps are shorted and the current draw is too high, and the protection circuitry is shutting down the inverter. You can check to be sure the main is working by testing the backlight on pin on the plug that goes from the main to power board, you need to see 3.3 vdc on that pin when you power the set on and it needs to stay at that voltage or you have main board issues
2answers
Samsung TV UN60H6203AFXZA screen is blank. Red LED start light just continuously blinks
This issue is usually caused by a bad power supply but it can also occur in some cases due to a glitched HDMI link.
I have a un60h6203afxza Samsung the picture and sound went out now the red light flashes and when it flashes the backlights flash with it
Count the number of flashes then Google that number fur your model. Each flash represents a different problem.
1helpful
2answers
I have a Samsung UN60H6203AFXZA (Version GH02) TV that won't power on and the red standby light is not lit.
Your issues come from the hot side of the power supply. You can replace the power supply and it should work again or if your capable of repairing it yourself you can do that for a few bucks. below is a link for a new PS, also shopjimmy.com would have one
Samsung Power Supply Board BN44 00772A for UN60H6203AFXZA eBay
I have a samsung un60h6203afxza and half my screen is dark and has a red tint.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2answers
I have a samsung 60 inch led that passes flashlight test. power supply is BN44-00775A. does that board also drive the led's or do i have to find the backlight driver?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" or the " power board number" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
 Grubhead
Grubhead
