2005 audi a4 cd player shows error sometimes when playing on different tracks . tried cleaning disc. no luck. what else can i do?
Posted by Tracy Dunn on
1helpful
My cdp-455x is showing a loading error after the lazer being cleaned
The laser eimission might have stopped. The laser pickup unit [optical pickup unit] should be replaced.
LG DVD player - disc will not load / showing disc error for all discs
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
My DEH-1950 IS SHOWING ERROR 17 WHATS THE CAUSE? WHEN I PLAY A CD SOMETIMES IT PLAYS AND SOMRTIMES IT SHOWS THIS ERROR 17 WHAT COULD REALY BE THE CAUSE OF THIS.
Typical Error Messages from this head unit:
  • ERROR: 11,12,17,30 / Cause: Dirty Disc /Action: Clean Disc
  • ERROR: 11,12,17,30 / Cause: Scatched Disc / Action: Repace Disc
  • ERROR: 10,11,12,15,17,30 / Cause: Electical or mechanical / Action: Turn the ignition ON and OFF, or switch to a different source, then back to the CD player
Try a CD Head cleaner, that should resolve this error.
Ripping audio CD-R's with Windows Media Player
use a different ripping software, the best is Nero and it does many other work by finetuing the audio tracks...
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
CD playing erratic
Run a "Laser Lens Cleaner" thru the unit a couple times. Use one that takes fluid, you can find them at just about any retail store for 15-20. If that doesn't solve it, it needs to be repaired. At that point weigh the cost over replacement. A new transport usually will cost 100-150 on average for parts and labor. Hope this helps
2answers
Error Message
sounds like the lens is dirty -try this out you kow them cans of stuff they use to clean keyboards with its like filtered air or something -try to blow out the guts of the cd changer with one of them cans and maybe it will help with functionality do the same with the cartridge emtied out and then run a cd lens cleaner disc and see if that does the trick-
2003 audi a6 cd player error 2
HI,THE REASON YOU ARE GETTING AN ERROR MESSAGE IS BECAUSE THE MECHANISM IS FAULTY,YOU WILL HAVE TO HAVE IT REPAIRED,ANDY
Player only plays first 3 tracks on CD and then stops
the emitting diode is not shiffting right..it might need some cleaning of its track..open it and check it out. good luck
Ekse
 Grubhead
Grubhead
