Televison & Video Logo
Question about Vizio Televison & Video
Want to fix my Vizio D55u-D1 TV. Anyone have experience?
Have had this Vizio for about 5 years. After 1 year it began freezing - the picture froze with the only solution being to hit the power button. It would then take a minute or two to restart. Figured since not happening sometimes for a week that we could get by. Then we've just noticed flickering in the upper left portion of the screen - there's a band that gets dark going from the left side to the middle and another one above it near the top that's not as bad. The other freezing problem persists as well.
Posted by Jon Ray on
  • James Hoganson
    James Hoganson Jan 13, 2023
    I am having the exact same problems with mine.
ADMIN Andrew
    Top Expert:
  • Vizio Master
  • 57,483 Answers
Posted on Jun 13, 2021
1helpful
Vizio 55" D55u-D1 has no picture or sound. white indicator light flashing
You have main board issues, the write protect circuitry has caused the EEPROM data to become corrupt. A new board will be very hard to find and expensive, I've attached a link below for a new EEPROM however it's not something most people can replace it takes some special equipment and a lot of solder skills because of the very small size and the pads are easy to lift. Another option is to send your board in for repair, look on ebay and you will see places that do it like Copell TV.
Vizio D55U-D1 has no picture
https://www.youtube.com/watch?v=f324xmqpsMs
https://www.youtube.com/watch?v=Bcz39rzy0o0
Press and hold the 'Mute' button on your remote for 5 seconds to ensure your screen isn't muted. Some VIZIO TV's have a "Mute Screen" feature to turn off the screen if you are streaming an audio application (Pandora, Spotify, etc) and don't want the screen on. https://support.vizio.com/s/article/No-Video-No-Picture-Black-Screen
Vizio d55u-d1 no picture or backlights. The capacitors look normal and no burn marks on the boards. I turn it on and the power lights fades, blinks 15 times then shuts off.
Hi Push3866, so you might have a failure in power supply or main board
Hola Push3866, por lo que cmentas podrias tener falla en fuente de alimentacion o en placa principal
Vizio D55u-D1 does not power on and the optical light stays off (does not flash orange or turn on and fade) when attempting to power on the TV. Could this be a problem with the main board or power board or...
If the status light doesnt light at all the first thing to check is the power board.
If you dont have experience it can be a dangerous procedure, do it at your own risk, TVs keep charge even after unpluging them.
I would check the fuse right after the power inlet and go from there. In my experience about 1 in 10 LCDs have only a blown fuse from a power surge, however it is IMPORTANT to check the rest of the power supply board before testing with a new fuse (i normally use the oportuny to change bulged capacitors and check voltages), if the cause was something other than a power surge it could do a bigger damage and ruin the board.
Hope it helps
1helpful
My Vizio D55u-D1 screen went black with a purple blue circle in the corner only. Has sound. What part can I try and replace to fix this?
Hello DD777, it would be good to send one or more pictures of the screen showing the failure that occurs, to be able to evaluate the possible failure and find a solution to the problem
I wait your answer
Greetings Franco Dosil
Hola DD777, seria bueno que env?es una o mas fotos de la pantalla mostrando la falla que se produce, para poder evaluar la posible falla y buscar una soluci?n al problema
Espero tu respuesta
Saludos Franco Dosil
Vizio d55u-d1 power light comes on then fades off. No sound or picture. Replaced power supply board, nothing still.
Chances are you have a main board issue, you should have run some voltage tests before replacing the power board, its sad how many people order boards that aren't bad because they don't do the necessary testing prior to ordering boards.
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
