Not worth repairing at that age in my opinion. Technology has moved on in picture quality and prices have become more competitive. Dynex was a budget make to start with.
https://www.google.com/search?q=dynex+tv
SOURCE: TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes.
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
SOURCE: Sony 36' TV Volume Goes up on own/Stuck on Video 2
Hi -
I had the exact same problem recently with my SONY Trinitron 27 inch TV! After trying everything, I found that pushing the Up and Down volume controls on the TV panel (ie NOT on the remote) at the same time, the problem went away. I hope that this helps!
SOURCE: Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
SOURCE: Hitachi 55hds69 plasma television. TV is 15 months
I will try replacing both y and z sus boards very common but also very expensive so prob keep checking on ebay.Also check the buffer boards
