SOURCE: Sd card
I had the same problem. so what i did is i created a back up on my computer and format it the sd card. and it had a bad file in it that was causing the problem. once i format it the card it was ready to be used again. just make sure you look for that corrupt file so you don't put it again to the already clean card. also i removed the sd card from the g1 and plugged it straigt to the computer. I hope this can help you like it helped me.
SOURCE: 8gb micro sd card does not work. lg vu cu920. is there a fix
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
SOURCE: cant view video off my mini sd card when i put it in computer
Try Downloading Quicktime to your PC. Its free and it plays 3GP(Mobile Phone) and MP4. Which is probably the format your phone is saving the videos in.
http://www.apple.com/quicktime/download/
Download Link is on the Left.
SOURCE: my pioneer indash avic d3 wont play dvd's you
this until has a safety feature installed that will not let you view video while in motion. it has a light green wire on the back that is supposed to be connected to the cars ebrake wire so that in order to view video you would have to have your ebrake ingaged. it also allows you to be able to type in address for the navigation. if this wire is not connect or not connected properly, you will get a messages that says drive can not view video will driving..
double check the connection....or you can just bypass it completely. i have attach a link on how you bypass this feature which will allow you to watch video and type in nav address while drivin
http://avic411.com/forum/viewtopic.php?f=11&t=7998
