The TV only had half a picture on the screen before it went out.
SOURCE: Half of the screen is black and doesn't display the picture
Send it back this appears to be a major failure
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
SOURCE: Vizio plasma. screen went black, and the power light went out.
Sounds like the power suply went. I don't know that model off the top of my head, but you might find a replacement here http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=EU&Category_Code=PLA
-=/ Daft Tech /=-
SOURCE: My Vizio TV Screen went black last night. I cannot
The slave inverter problably went out. Good luck finding if it is a 6632L-0471A The same thing happened to me and I can not find one.
SOURCE: I have a Samsung Ln32A450c1d
Basically it is problem of LCD Panel (screen) however some times T-Con board replacement fixed the issue (T-Con board is part of lcd panel but some part shop sell it separately). Main board is not related with this kind of problem.
Required T-Con board is available in ShopJimmy.com (click the link to view available boards)
If T-Con board replacement does not solve half screen vertical lines problem then LCD Panel will be replaced and it would cost approx new tv price.
Hope this info will help.
Thanks.
