Question about Measuring Tools & Sensors
Robinair 34700z display went blank yesterday... Machine runs, but no display. Is there anything I can try myself before taking to dealer?
Posted by Andrew Welch on
ADMIN Canada
    Top Expert:
  • 40,480 Answers
Unlikely, unless you fancy trying to check the connections behind it? It doesn't appear to be a known issue.
https://www.google.com/search?q=Robinair+34700z+display+went+blank
Posted on Jun 02, 2021
3 Related Answers
Anonymous
  • 10594 Answers
SOURCE: Sony handycam DCR HC20E: LCD blank
Your Sony DCR-HC20E camera has defective CCD Imager and needs to be replaced. Good news Sony UK (if you are in UK) will repair it free of cost. Please click Sony UK for details.
If you are some where else, please let me know to guide you.
Regards,
Posted on Aug 28, 2008
RickE1
Rick
  • 202 Answers
SOURCE: Bernina 440 QE -- Freezing with blank display
Definatly it is an electronic issue. Have the cables checked to be sure there weren't any pinched between the covers etc. And that the plugs on them are seated properly. This they should do naturally. I have also seen this before when what is called the EEPROM chip went bad. Screen lit, no info. The EEPROM is a small chip, black and rectangular on the S-Print board,The EEPROM stores all the information for the machine to work. The screen will light but no info on the screen if its bad. Before replacing a whole circuitboard I would suggest replacing this. It just plugs and unplugs from the S-Print and much less expensive.
If your not feeling all that trustworthy if the tech can do it then ask that it be sent to Bernina in Illinois and repaired. It could take 6 weeks though.
Posted on Feb 11, 2009
Anonymous
  • 2335 Answers
SOURCE: Rebel XS was working fine... yesterday, all of a
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Posted on Apr 15, 2010
Robinair 34700z will only fill 1/2 of recommended refrigerant
Try running the compressor for a while,then see if you can get more into the system on the low side,not the high side while it is running,until the sight glass on receiver dryer clears from being milky.
2helpful
I have a Robinair 347002K abnd cannot access anything under defaults. Defaults show as a menu item, but I can not see or select anything else under that heading I tried the 5454 password i saw on another...
You may did not try in the right way! The access code (5454) is 100% right for 347002K/347112K and 34700Z new series machines. If keypad has oil injection button (old series machine) press 8787 on keypad.
However you can try as following: To access the change Defaults menu press 5454 (If keypad has oil injection button old series machine press 8787) on the keypad then press ENTER/START arrow key. Now display will change to "Calibrate Scale". Press up or down key to select option you wish to access from: Set Tank Tare, Output Test, Input Test, Keypad Test. Prepare to Ship. Reset Board Memory etc...
NOTE: DO NOT CHANGE 'SET TANK TARE' OR PRESS 'PREAPARE TO SHIP' & RESET BOARD MEMORY' IF YOU ARE NOT FAMILIAR WITH THIS MACHIN!
Hope this will help you. Good luck!
3helpful
Can my Robinair 34700Z be set to recharge in ounces instead of pounds or pounds/ounces (EX. 2.4 lbs.)?
You can not use any Robinair machine in ounces to recharge refrigerant instead of LBS or KG. the software is not programed for count refrigerant in ounces!
Hope you get your answer
2helpful
Machine says pressure exist unable to vacuum system down
It's not clear that you machine is doing recover or not! If the machine is doing recover theh follow the bellow steps.This is a common problem of Robinair 34700Z / 347002k
7helpful
2answers
AT MACHINE TURN ON DISPLAYS UNDER HIGH PRESSURE AND DISPLAY SAYS TO RESET WITH MAIN MENU BUTTON.BUT WILL NOT RESET
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just check the following :- 1# Verify the ISV tank is not overfilled.if full,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid & High pressure switch for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
2helpful
2answers
Robinair 34700z displays toggle input, input 0
You can try 1# With power on press and hold for 4/5 sec. up & down arrow key at the same time
2#With the power on press YES/START & NO/STOP key at the same time
Wont vacuum
With machine power OFF,remove old pressure transducer & replace new one.now power ON the machine & go for calibration.Calibration step for Robinair 34700Z machine.Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
4helpful
I need to replace the filter in my Robinair 34700Z machine. Where is it located? And where can I find a manual to go with this machine? Mine is missing. . .right when I need it.
Press the main menu key,then upper arrow & go to "Change filter" option,then press "Yes" key & now follow on screen message(Do not skip any option while active ''change filter'' option).
Filter located on back side of the machine & fixed with the manifold assy.it's long black color & you may see the sticker with part no# 34724 (spin-on filter dyer).
For user manual you can try to robinair web official site www.robinair.com
3helpful
Machine will not clear existing pressure
Please check your unit compressor also & make sure compressoe haveing minimum 13''Hg suction.
8helpful
I have a robinair cool tech 700 not recovering
You Need to replace your unit compressor.Because may be you did not change spin-on filter after recovering 150 LBS of refrigerant.
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Tom Chichester
ray gallant
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
