Https://pinoutguide.com/Car-Stereo-Toyota-Lexus/Lexus_P3918_pinout.shtml
https://www.google.com/search?q=2004+lexus+rx330+radio+wiring+diagram&safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk02y4rbAXxD0u9BR87rM3sgx5Zx3iA:1622600731425&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjbudXh8vfwAhVUbc0KHVfbAjoQ_AUoAXoECAEQAw&biw=1920&bih=937#imgrc=j6uR1zKWEyM-yM
SOURCE: stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
SOURCE: i need to know which
my reccomendation would be to pick up a wire harness at circuit city or best buy for $20-30. it will connect your cars wire harness to the radio without you having to do any wiring. but if you want to send me the yr, make and model of car, i will get that for you. thanks
SOURCE: wire color to radio
light green and dark green -- right front speaker
tan and gray -- left front speaker
light blue and dark blue -- righr rear speaker
yellow and brown -- left rear speaker
orange -- constant power
yellow -- switched power
black w/ white stripe ground
always use a dc electrical test light to be certain your power connections are correct.
SOURCE: 2004 ford escape wiring diagram
This is for 2005 Escape, its possible that can helpfull... LINK
Hope this help.
