SOURCE: Canon PC 1060 error code E-002-000
A E002-000 is fixing unit error code. It is a power problem with the fixing unit. When you removed the paper jam did you see any piece of a blackish grey plastic pieces. If so you need to replace the fusing unit and or the upper fixing film..
SOURCE: Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
SOURCE: CANON PC735 COPIER, PAPER JAM
For the problem with the personal copier pc735 paper jam, I had the same problem. I was told the problem might be fixed by downloading the drivers and reload them. The PC735 I have does not have drivers nor a scan. My problem was a spring fell off on the idler gear and had to be reattached. I then cleaned the interior and this fixed the copier. You might look to see if a spring came loose on the back side of the bottom frame. I'm no machanic so I had a canon rep fix it for me. This fixed my problem. No more paper jam light.
Bob At [email protected]
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
SOURCE: 202.01 and 202.03 Paper Jam
The 202.03 error code has to do with an early life failure of the fuser. Try replacing the fuser. If that doesn't work, a tech is needed to replace rear door. Don't forget to reset maintenance counts when you replace fuser!!
