the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
If you want the drain to be ducted the measurement is about the size needed for the drain pipe. Normally a duct with an OD- outer diameter -of about 3 inches should be sufficient to plug in the drain hose .
Make sure your drain hose fits into the duct as you can buy one with the drain hose taken out to sample.
Turn off the circuit breaker that controls the dishwasher.
Open the dishwasher door. Locate the two small screws holding the bottom valance trim piece. Remove the screws and the valance, revealing the lower pump assembly and drain-hose connection.
Remove the hose clamp. Disconnect the drain line by pulling the hose.
Find the other end of the drain line under the sink; it is connected to the drain tail piece or the garbage disposal. Remove the hose clamp and disconnect the drain line. The dishwasher drain hose is now disconnected at both ends.
5
Pull the dishwasher drain hose into the sink base through the hole between the dishwasher and the sink base.
6
Take the dishwasher drain hose outside or to a wash sink. Run hot water through the line to clean and unclog it. When you see water running freely through the hose, then it is clean. If the hose cannot be cleaned, replace it with a new drain hose of the same size and length.
7
Feed the clean dishwasher drain hose back to its original configuration. Reconnect both hose clamps. Reinstall the valance, turn on the circuit breaker and test-run the dishwasher.
Just pull the gas line off of the carb. If the end of the hose is difficult to access, you can cut the hose, then put it back together with a brass hose barb. To be sure of the size, you can cut of a very short piece of the hose. I've been looking for a drain valve that could be installed instead of a hose barb myself. I don't know why these medium sized generators don't come with them.
Contact the pneumatic dealership / hardware shops where a variety of hose sizes will be available. Take the sample size hose and measure the length required for the drain.
try this link for an universal type hose
This error code indicates that drain times are longer than expected.Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. Use only HE High Efficiency detergent. The excess suds will slow or stop the removal of water from the washer. Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent. Using non-HE detergent, or
more than the manufacturer's recommended amount of detergent, can cause
excessive suds. The excess suds will slow or stop the removal of water
from the washer.
recommendations.
drain hoses are quite standard. the rubber spigot at each end can be different sizes and some have a right angle bend at the end. suggest you take out the old hose and take it along to match up - easiest way
