Question about Canon Cameras
When insert any sd card canon 70d says cannot creat folder
Posted by Jose Mascarenhas on
Aron
  • 2,095 Answers
The part where the SD cards are inserted could be dirty and should be cleaned out with qutips and rubbing alcohol or it could also needs replaced as well.
Posted on Jun 01, 2021
5 Related Answers
Anonymous
  • 40 Answers
SOURCE: saving music on my micro sd..
well assuming you loaded music on your sd card:
to find it, just go to mystuff....
menu, mystuff, center button, it should load the mini sd right there. then all you have to do is click over right and file explore the mini sd. you should put music in the music file.
another option on the phone.....
go to att music
menu, upper left icon, center button, music player, it should find all files.
let me know how i can help some more
Posted on Feb 24, 2008
cricket0321
SOURCE: sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Posted on Sep 27, 2008
Anonymous
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
Anonymous
  • 15 Answers
SOURCE: When i put my SD
This error occurs most of the time when the SD card is corrupted, not formatted, etc. Try to format your SD card using your digital camera. If this doesn't work, try to format your SD card using your computer. If it still doesn't fix the problem, your SD card is probably defective.
Posted on Dec 25, 2010
Anonymous
SOURCE: how to format the sd card for nuvi 1390t
I found the solution on my own. My PC is a Win 7 64bit machine and I was using Google Chrome Version 18. When I tried the download again using IE, it worked fine. I now have 3 full maps on my Nuvi 1390 (i in the internal memory and 2 in the SD card) and can access each one without a problem.
Posted on May 12, 2012
My nokia c101 is not showing my sd card
Copy everything on the MC to the computer, then format the MC. It'll probably work. The problem was that you may have deleted a system folder of the card, created by the cellphone.
7helpful
3answers
The memory card says card cannot create folder
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
After unprotecting the card, insert it into the camera and format it.
Kodak C190 camera. I moved my pics from my SD card to my computer. Then tried to transfer them back..after many tries, they are back on my SD card. I can view them by putting the SD card in my laptop. When...
This should do it for you: Insert the SD card into your laptop or computer. In the SD card go to "New Folder" name that folder "DCIM" in the "DCIM" folder create a new folder. This one you will name "101KC190" (I'm pretty sure you have the Kodak Easyshare 190, correct?) Now, transfer all of your pictures into "101KC190." Insert the SD into your camera and it should work. email me if you need to [email protected]
3helpful
2answers
When i put my SD card in, there's an error saying 'cannot create folder'
1helpful
2answers
I own the r451c which has an mp3 player, but when i insert the micro sd and go to music player, i get a prompt that says no mp3, what am doing wrong
You have to load mp3s on the micro SD card via the computer. To do it properly, you must place the mp3s in the folder that says My_Music which is located in the micro SD card. That folder is created once the micro SD card is first inserted into the phone.
I hope that helps.
Copy from camera to SD?
Create a folder on your computer desktop. Drag and drop the video file from the card to the folder. Open the folder, right-click the card, click on open with, and choose a player to open the video. If you don't have one on your computer, Quicktime is a free download and works very well.
How do i transfer music from my computer to my palm treo 680? i have and sd card in my phone but it only allows me to download pics
format your sd card using your treo 680. then you insert your sd card to your laptop or into a card reader so you can transfer music files from your computer. create a folder to the main directory of your sd card and then rename it to "AUDIO". you may now save music files to that folder.
you can now play music files to your treo 680.
1helpful
How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
1helpful
2answers
Transfer the music data from PC to Motorolla W230
Dear this is the main solution.
create the folder of MUSIC in ur memory card. copy songs in music folder
create the folder of picture in ur mem card and copy paste the pics of it
when u insert the memcard in ur handset and u'll show all the data on ur phone
Memory card
When you use an SD card in mulitple cameras, each camera creates it's own folder beneath the DCIM folder. I'm not sure if you have a program that automatically opens when you insert the SD card in your reader, but perhaps you can try double clicking on "My Computer" and locating your reader/SD card and opening that folder manually. Once you're there, open the DCIM folder and see if there are multiple folders inside. Open each one to see if you can locate your pictures.
If you have a program that opens automatically when you insert the SD card you'll need to figure out how to tell it to look in other folders.
Cameras Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
