SOURCE: walky talky
A walkie talky as we called them, back when we were younger - and hell we probably still do in some respects, hence the fact my friend still refers to her cordless phone as a "walkie talky" and the principals haven't changed that much.
The common old Walkie Talky or CB radio use what we call a half duplex, that means only one person can talk at a time. We are talking and listening on the same channel.
Cell phones are full duplex, meaning two way conversation, and this is simply listening on one channel whilst talking on another, so the basic principal is basically the same, just a little more sophisticated.
Walkie-talkie typically has one channel
CB radio has 40
channels.
Cell phone can communicate on 1,664 channels or
more!
I have included a link to a circuit diagram.
http://www.freeinfosociety.com/electronics/schemview.php?id=1870
There is also two links below, building the transmitter & receiver.
Transmitter: http://www.zen22142.zen.co.uk/Circuits/rf/2bjttx.htm
Receiver: http://www.electronics-tutorials.com/receivers/regen-radio-receiver.htm
Trust this helps, and please take the time to rate the answer given, thank you.
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either + or – to turn On or Off.
3. Press the PTT to confirm or MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
SOURCE: Is Bell South walkie talkie compatiable with other
Some number their channels differently, but all FRS/GMRS radios operate in the same mode and will have at least some frequencies in common. Check the channel/frequency lists for both radios and you'll be able to talk to each other.
SOURCE: The battery is fully charged
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
SOURCE: Motorola XTR 446 talkie walkie is not receiving
Try programming the radios without an eliminator code and see if they work together then. If so, there is something wrong with the eliminator code portion of the radio. Also, check your batteries, switch batteries between the units and see if the problem moves to the other unit. It takes more energy to transmit than receive, so a bad or very weak battery could exhibit a similar problem. The radio icon will illuminate whenever a radio is transmitting or receiving. When the radio is in standby mode, the icon should not be shown. Your radio with the icon on all the time may be stuck in transmit. Check your PTT button to see if it is slightly stuck or depressed. Here's a link to the user guide http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103
Best regards.
make and model of talkie
the google and RTM read the manual, all made have manuals and all are free, to read.
even back to 1960s.
best is that, get the PDF and save it for when needed, even in a hurry.
I have mine set to whether service, chan. local. 2meters.
I am answering for HAM handy Talkies
only not kids toys or those seen in walmart in dual blister pack and some are china only no-named radios
called toy grade. by all.(but super useful)
post a photo of yours, end guessing.
