How do I change the voice guidance language? ' Jabra ...
https://www.jabra.com > ... > Frequently Asked Questions
Connect your Jabra device to a computer. · In the Updates section on the product support page, select the firmware language and download the file. · Open the file ...
SOURCE: Change Windows XP language from Chinese to English
If the menus are all in Chinese then you will need to install an Enlgish version of Windows XP.
SOURCE: language change
Press the check button and the right arrow button in this combination:
check, arrow, check, check, check.
This should bring you back to the ready screen after a brief pause.
SOURCE: CHANGING PRINTER CONTROL PANEL LANGUAGE
See solution below:
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Thanks
SOURCE: Want to Change Language
Dont purchase cameras with japanese language in future if they dont provide translation in english..
SOURCE: tomtom GPS language setting
Do this whilst it is disconnect from a PC
Whilst it shows a map display touch the screen once.
Select the icon that looks like a spanner / wrench
Use the rght arrow on the display until you see a bunch of flags. (if you shoot past it just keep going until it comes ound again)
Touch that and select the correct the correct flag / language.
is this USA rig?
a you in USA or UK or india or?
now I decode you r post
Jabra F600
it s not a RADIO at all posted to Comm Radios
it is actually a
Jabra F600 Bluetooth Headset (used as a head phone for sound)
I guess using this for PC, running windows?
it only works on
"Smartphones, both Android and IOS, Tablets PC, etc."
I guess you mean how to change the driver for it on windows 10? that? to a new language
why not first tell what it is paired with ???????
