Re: My candy washing machine incidates aquaplus button...
Hello, I have the same problem but after following the procedure mentioned (pish the button 5 min etc etc) the error still occurs during the self test mode
Hello, I have the same problem but after following the procedure mentioned (pish the button 5 min etc etc) the error still occurs during the self test modeHello, I have the same problem but after following the procedure mentioned (pish the button 5 min etc etc) the error still occurs during the self test mode
You can't post conmments that contain an email address.
sounds like overload protection is disabling the machine. it could be caused by a lot of reasons, the only advice I have is to check for a jammed drum, empty machine and see if drum turns freely. best luck to you.
have you checked the filter is the mach niosy if you pull the machine out lower the drain hose into a basin and see ithe water runs out if you tilt the machine backwards before opening filter you will have less chance of making a mess hope this helps
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
