Televison & Video Logo
H
House Posted on May 26, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung LED DLP 1080p TV (HL61A750). I have sound but no picture. It takes several attempts for the TV to actually turn on, if at all. Can you help diagnose the problem?
ADMIN Andrew
Level 3:
Top Expert:
  • Samsung Master 66,963 Answers
  • Posted on May 26, 2021
ADMIN Andrew
Samsung Master
Level 3:
Top Expert:
Answers
66963
Questions
Helped
5086538
Points
379812
It depends if you are a Digital Light Processing engineer?
LCD and DLP are two new and different imaging technologies for flat screen TVs. LCD stands for Liquid Crystal Display and DLP stands for Digital Light Processing. Both produce accurate and sharp images. The differences are in display, price and performance. ... Both DLP and LCD television screens are slim and lightweight.
Best advice is here
https://www.fixya.com/support/r29790007-repairing_own_television
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
Samsung DLP TV has power but no picture.
There is a capacitor that often fails.. it round and contains a thermal sensor.
White dots on screen
http://www.metacafe.com/watch/yt-XeIOwN1CIp8/samsung_mitsubishi_toshiba_dlp_hd_tv_repair_tips_black_white_dots_on_tv_problems_bad_dlp_chip/
I believe it is the digital projection chip that is beginning to fail. Causing white and black spots to appear. To repair this may cost more than a new tv. If you want to attempt it yourself check out the above link. Hope this helps
Samsung hlt5087 sax soung but no picture.
I have a 36inches Samsung LCD TV. When it is on there is no picture but all control is working...what is the possible problem of my Tv
Samsung 1080 picture glitching on model # HL61A750a1fx2c Versionre01
If it's all colors (Red, Blue, Green) doing the same thing at the same time, there are (unfortunately) multiple possibilities:
1) the AC to DC power supplies
2) the LED Driver Board
3) DLP driver, or DLP itself
The most likely problem is the DC-DC power supplies, which are known to have capacitors that go bad after several years of operation.
Due to this, there are many sources for either re-capacitor kits (DIY), or rebuilt power supplies with upgraded capacitors.
WARNING - Dangerous, and even lethal voltages are present inside your TV set. Do not attempt this unless you are trained in these kinds of repairs. Leave the TV unplugged for several hours (or preferably a full day) before attempting such.
DIAGNOSIS for bad capacitors: If you inspect the large capacitors on the power supply boards, and they are not totally FLAT across the top surface (if bulged at all), then you need a new power supply or new cap's. Likewise, if there is any leakage from the capacitors (usually a light-yellowish crusty appearing substance), they are BAD.
Sub-power supply:
BP96-01726B ASSY PCB P-SMPS Aquamarin,LED DLP TV,DC2
Main power supply:
BP44-01001A SMPS-DLP TV PN082DPS-VF(A),AC/DC,90V-132
A quick Google search for these part number (BP96-01726B & BP44-01001A) will reveal many sources, and pictures to verify it's what your set has.
1helpful
Broken 56" Samsung 1080P DLP There
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this help to rectify the problem.... and do take care in handling the Television
Looking for technical help for Samsung 61" 1080p 120Hz Slim-Depth LED Engine DLP television . I have sound but no picture. 3 flashing lights on from of panel; timer, lam, and standby/temp
Hope you got helpful info from our expert to solve your tv issue, if you still need further help, let me know to assist you further along with info what actions have been taken to fix the problem.
Thanks.
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
